January 31, 2026, 08:20:28 PM *
Author Topic: button for turn signal broke!  (Read 2169 times)
Fajack
« on: July 20, 2010, 10:15:22 AM »
My turn signal button broke inside the housing.  Is there any where other than a dealer I can get a new turn signal housing?  I spoke with someone at Inzane but forgot the website
Jack
Farther
Quimper Peninsula, WA
« Reply #1 on: July 20, 2010, 10:58:11 AM »
http://www.hdlparts.com/fiche_section_detail.asp?section=148815&category=MOTORCYCLES&make=HONDA&year=1998&fveh=3477
~Farther
« Reply #2 on: July 20, 2010, 02:49:24 PM »
Pinwall has a lot of those exact parts (the whole assembly) and they are very reasonable.
fuzzy2bucks
« Reply #3 on: July 21, 2010, 06:31:26 PM »
Should the aforementioned turn signal button be lubed?  If so with what?   White lithium grease with the small red tube to enter the slots next to the button?
« Reply #4 on: July 21, 2010, 06:47:10 PM »
A can of electronic cleaner/lube from CRC or Radio Shack (with the small red tube) is good for all the handlebar switches..... especially after every wash or rain ride.
http://www.acehardwaresuperstore.com/crc-marine-electronic-cleaner-p-66233.html?ref=42
http://www.zipzaps.com/pwr/product-reviews/Cables-Parts-Connectors/Chemicals-tape-adhesives/Cleaners-wipes/RadioShack/p/2103700-TV-Tuner-Control-Cleaner-Lubricant.html
donaldcc
Palm Desert, CA
« Reply #5 on: July 21, 2010, 07:36:58 PM »
Jess,   are you just spraying the switches with the cleaner after wash or rain??  Undecided
Don
fuzzy2bucks
« Reply #6 on: July 21, 2010, 08:02:39 PM »
Radio Shack TV-Tuner/ control & lube, model 64-4315 . . .  $10.99 seems to be the better choice because it is also a lubricant as well as a cleaner.
The Ace CRC Marine electronic cleaner is not a lubricant , it runs $7.55 to 8.39.
Tx
Valker
Wahoo!!!!
Texas Panhandle
« Reply #7 on: July 21, 2010, 08:14:45 PM »
I take mine completely apart every 3-4 years, clean it with electronic parts cleaner and lube it with dielectric grease. Be sure to clean the tiny detent ball on the back side. Works easily for a long time then. cooldude
« Reply #8 on: July 21, 2010, 08:54:19 PM »
Yes.  Try to insert the skinny tube into the switch internals, squirt and gently work the switch.  Use under the side covers, locks and ignition too.
I'm not adverse to taking switches apart and doing a better job, but have never needed to.
