July 18, 2025, 02:00:14 AM
rear drives
Topic: rear drives (Read 1098 times)
triumph 69
Bean Station TN.
rear drives
July 23, 2010, 08:11:18 AM »
will the rear drive units from the 97 to 03 valks interchange with the 97 to 03 goldwings thanks keith
ride it like you stole it
02 triumph america 99 valkyrie 02 roadstar
69 triumph bonnville 89 goldwing
Re: rear drives
July 23, 2010, 11:05:17 AM »
no
triumph 69
Bean Station TN.
Re: rear drives
July 23, 2010, 01:49:25 PM »
on a goldwing site steve saunders has a goldwing history page on all year wings and in it says that in 97 goldwing used a lot of parts from the valkyrie and that they share the same final drive I don't know just wondering if they would work
Re: rear drives
July 23, 2010, 02:11:42 PM »
I believe the meaning in that post was that gear ratios are teh same. I have watched many dicussions on this and the consensus seems to be that all but one final drive bolt lines up from wing to valk. Now I do know that some 1500 wings use the same drive shaft, so that means the pinion cup must be the same and probably u-joint. But as far as I know the swing arms are always different
SCain
Rio Rancho, NM
Re: rear drives
July 23, 2010, 02:15:14 PM »
The spline flanges both Male and Female are interchangeable from a GL1500 Goldwing to the Valk. These are the only parts I know of that are the same in both rear diff's.
Steve
triumph 69
Bean Station TN.
Re: rear drives
July 23, 2010, 04:13:47 PM »
thanks guys
=> InZane XXV
