July 18, 2025, 01:49:28 AM *
Author Topic: What else might I need?  (Read 1783 times)
Tropic traveler
Silver Springs, Florida
« on: July 23, 2010, 04:35:45 PM »
OK, I was waiting for the rear Avon to wear out before I pulled apart my '97 to do some high mile servicing but a well placed nail has forced me to tear it down now to replace the tire. Sad   It now has just under 103K & everything except the bearings & brake pads are original.
The parts I have gathered so far:
New rotor & bolts {original is SHOT!}
New pads.
New bearings. {last replaced at 68K or so}
New dampers {Gary's}
Used trike conversion U-joint {> 20K miles}
New O-rings {all 3}
New flange... just in case
What I know I don't have is spline lube as I have had the local Ducati dealer change all my tires so far, but now I have the time & inclination to do it myself.
What kind of spline lube should I get & where to get it?
Any other pieces & parts that I should have on hand?
Other than the well worn rear rotor everything else is good as far as I know. It does have some driveline slop but not excessive for the miles. I'm just one of those guys that wants to do it all while I'm there!
Any suggestions? I have some time to gather more parts while the tire is enroute.
Thanks, Eddie.
'13 F6B red for Kim
Michvalk
Remus, Mi
« Reply #1 on: July 23, 2010, 05:10:23 PM »
6 beers and an airconditioner? uglystupid2 cooldude
Thunderbolt
Worthington Springs FL.
« Reply #2 on: July 23, 2010, 05:45:25 PM »
I have had good luck with it and results so far.  I bought mine at my local independent bike guy,he ordered it from partsplus.  Check the thrust washer while you are in there.  Tighten the 4 shaft tube nuts last.  Be sure the boot is on around the u-joint on both ends.  The rest you already mentioned.
« Reply #3 on: July 24, 2010, 02:43:00 AM »
You asked about rear spline lube.
I have used Del-Ray waterproof front wheel bearing grease since day one.
I get it at the local Auto Parts store, like O'Reilly, Pep Boys. Advance and so forth.   What I get comes in little tubs.
9Ball
« Reply #4 on: July 24, 2010, 03:48:53 AM »
New pads.
New O-rings {all 3}
Thanks, Eddie.
you didn't mention a new thrust washer....recommended
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #5 on: July 24, 2010, 04:32:11 AM »
Maybe get a caliper seal set (cheap) and maybe even those two rubber caliper booties... take it all the way
apart, clean everything like new...
« Reply #6 on: July 24, 2010, 05:47:51 AM »
You mentioned the rear rotor.........your fronts should be shot by now too
« Reply #7 on: July 24, 2010, 05:59:41 AM »
I have to say something here.......I have seen this put this way a few times and Im not sure you understand the requirement here.  Tightening the drive mount bolts last is a misguided way of describing the process.
To get the best chance at proper spline alignment you should have the right shock removed from the final drive....the 4 mounting bolts loose so the drive can move around on the end of the swing arm.
Place the wheel up into the drive, position the caliper plate and the spacer and slide the axle in from the right to the left. place the axle nut on by hand and then step back...
Make sure the tire is not resting on the floor
go ahead and replace the caliper plate pin to hold the plate in the right place so it doesnt interfere with the wheel drive interface
Once everything is right then torque the axle nut to 81 ftlb  and then you should immediately torque the four mountng bolts since you now have proper spline alignment.  Once the axle and the drive are tight it just doesnt matter what you do next or in what order, but certainely the drive bolts arent done last if you want a pure alignment
Colin
My old job
Orba, Spain
« Reply #8 on: July 24, 2010, 06:40:22 AM »
Change your brake fluid whilst you have it all apart.
Colin
VRCC Espana
My Bumble Bee re-build
Thunderbolt
« Reply #9 on: July 24, 2010, 09:04:33 AM »
 Smiley
Tropic traveler
« Reply #10 on: July 24, 2010, 09:32:29 AM »
Got that covered about 3,000 miles ago. GL1800 rotors & new Honda pads.  cooldude
Will do on the new thrust washer j.r.  Wink
« Last Edit: July 24, 2010, 09:34:04 AM by Tropic traveler » Logged
'13 F6B red for Kim
« Reply #11 on: July 24, 2010, 09:47:32 AM »
Change your synthetic rear end fluid while you are in there. 80/90
Tropic traveler
« Reply #12 on: July 24, 2010, 03:29:02 PM »
Mobil 1 full syn gear lube in it for the last 20K or so. Just changed it about 5K ago.
Good suggestions all.
Thrust washer ordered. Thanks jr!
Rear caliper replaced & bled about 10K ago, thanks hubcap!
« Last Edit: July 24, 2010, 03:31:52 PM by Tropic traveler » Logged
'13 F6B red for Kim
asfltdncr
« Reply #13 on: July 24, 2010, 04:26:33 PM »
The manual and archives are a pretty good source for lube and sequence of assembly.
Six Guns
Fort Worth, Texas
« Reply #14 on: July 24, 2010, 04:29:29 PM »
Per ShopTalk: Don't forget to replace the Dust Seal.......
The Elusive 3rd O-ring
And While You Are In There - Don't Forget to Replace the
Thrust Washer part # 42616-MAJ-G20   And The   Dust seal Part #91253-433-761 (30 X 47 X8 )
