My throttle stuck when I got my bike a few years ago. I lubed it with some good lube and it has
rocked ever since...
I couldn't get enough slack in my throttle cables to get the ends out of the grip-twist, so I asked
around here... a trick is to loosen the handlebar riser clamps (while protecting the tank - the bars
want to swoosh down and put a dent in your tank when you take the last riser bolt loose) and
push the bars to the left - then there's plenty of slack.
I put lube down the cables until it started coming out the carb end, dripping onto the motor.
Careful about your lube choice... I figure if you use WD40, it be great at first, but you'd have to
redo it soon. When we did my buddy Gary's cables, all he had was silicone spray, it didn't work all
that well even at first... This TriFlow is good stuff, and there's plenty of other good stuff...
