March 18, 2026, 05:34:53 AM
License plate frame....
Topic: License plate frame.... (Read 1134 times)
thumper
July 24, 2010, 01:41:30 PM »
Will this work on an '03 Standard?
http://www.directlineparts.com/product.asp?pid=7000&str=2
shortleg
maryland
Re: License plate frame....
July 24, 2010, 02:54:25 PM »
Not on your standard mounting. Your mounting now
is straight.
Shortleg[Dave]
July 24, 2010, 06:02:45 PM »
Quote from: thumper on July 24, 2010, 01:41:30 PM
It is designed with a curve in it so as to mount it flat against the fender.
If you want to make up your own, try this place on for size.
They make excellent frames... You provide the wording.
http://twochicks.com/
In the left column, click through the motorcycle ones for ideas...
