February 01, 2026, 03:51:49 AM *
Author Topic: Another good source for fuel shut-off valves  (Read 1856 times)
Warlock
Magnolia, Ms
« on: July 24, 2010, 06:35:32 PM »
http://www.mccampingsupplies.com/index.php?main_page=product_info&products_id=14125&zenid=3n1fvtcuj84u6q0i1skkj153b0
David
BonS
Blue Springs, MO
« Reply #1 on: July 24, 2010, 07:07:40 PM »
Looks good, they're identical. Don't know about the current draw though. My Dan-Marc valve is 1.25 amps; 0.75 amps sounds good. I wonder if there has been a change in the past year to a lower current draw model.
Warlock
Magnolia, Ms
« Reply #2 on: July 24, 2010, 07:25:56 PM »
It's the same model number. I have them on both of my Valk's and one spare. Thinking about ordering a couple more.
David
triumph 69
Bean Station TN.
« Reply #3 on: July 25, 2010, 09:13:19 AM »
do these cut down any on the fuel flow and which switch wire do you hook to
ride it like you stole it
 02 triumph america   99 valkyrie  02 roadstar
 69 triumph bonnville 89 goldwing
BonS
Blue Springs, MO
« Reply #4 on: July 25, 2010, 12:51:18 PM »
Yes, the valve does offer some restriction, but by itself or with the addition of a very free-flowing in-line filter provides sufficient flow for the Valk. You have choices on powering it. Some people use a small relay that is good for a couple of amps and trigger the relay from the ignition coils black/white wire. Others, myself included, don't use a relay. I ran a wire back to the 5 amp auxiliary power circuit underneath the right cover and this works well. When powering the solenoid directly from the ignition coils it sucked too much power and starved the coils at high rpm  uglystupid2 causing a bad miss.
