July 18, 2025, 04:00:10 AM
gas fumes
Topic: gas fumes (Read 1332 times)
v-man1
gas fumes
July 26, 2010, 11:22:48 AM »
have a gas fume smell in building where i store my valk.anyone know of possible causes,as i see no leakage and have no running problems?thanks
Re: gas fumes
July 26, 2010, 12:39:17 PM »
Quote from: v-man1 on July 26, 2010, 11:22:48 AM
Depending on strength, I'd not worry about it if you don't see anything.
Open a window.
N8171S
Marlboro, Mass
Re: gas fumes
July 26, 2010, 12:54:35 PM »
Is the gas cap tight? and check the vent tube for an overflow if tank is over full.
Thunderbolt
Worthington Springs FL.
some have carefully removed the gasket on the cap
July 26, 2010, 05:39:44 PM »
and put another thin gasket underneath it and re-installed original. Also, some folks have put tape over the keyhole to determine the source.
valkyriemc
NE Florida
Re: gas fumes
July 26, 2010, 06:50:53 PM »
Check under tank with hand, make sure petcock is not leaking. Open gas cap wide prior to going into garage. Then close it up, go in. This subject re-appears every so often. Try search. I was asking this same quest. back in 2002.
Last Edit: July 26, 2010, 06:52:47 PM by valkyriemc
Veteran USN '70-'76
RLD
'99 I/S Red/Black
Eden Prairie, MN
Re: gas fumes
July 27, 2010, 05:13:40 AM »
Mine has always been the gas cap; I buy a new one and end of problem. Some put another gasket in with success.
Dress for the slide, not the ride. ATGATT
VRCC #2505
Jabba
VRCCDS0197
Greenwood Indiana
Re: gas fumes
Reply #6 on:
July 27, 2010, 05:36:18 AM »
My gasket leaks a little. I grease mine and it's good for a while... then it stinks again, and I grease it up again.
Jabba
=> InZane XXV
