January 31, 2026, 11:28:43 PM *
Author Topic: i think i know the answer but  (Read 1803 times)
sugerbear
wentzville mo
« on: July 27, 2010, 10:57:13 AM »
found a broken exhaust stud on the left front.
i took off the left side exhaust, removed the broken piece, now
should i replace all the studs or just the ones that "look" bad?
p.s. bought 6 new studs/nuts and 3 gaskets.
thanks
p.p.s. i think i found the popping i've been looking for too Cheesy
« Last Edit: July 27, 2010, 10:59:52 AM by sugerbear » Logged
« Reply #1 on: July 27, 2010, 11:01:35 AM »
thanks
I wouldn't mess with the studs that will still work. Put anti-seize on the threads when you
reinstall the nuts, and carefully recheck the nuts after the first few rides as the new gaskets
get fully seated...
-Mike "might not be the right answer  Smiley "
Scott from FL, now in Maine
Augusta, Maine
« Reply #2 on: July 27, 2010, 11:13:34 AM »
+1 to Hub   Cool
RoadKill
Manhattan KS
« Reply #3 on: July 27, 2010, 04:44:42 PM »
+1 to Hub   Cool
+2...then you have extras JUST in case it happens again, Stuff happens!! Embarrassed
Be prepared  cooldude
sugerbear
wentzville mo
« Reply #4 on: July 28, 2010, 07:12:33 PM »
just finished putting it all back together. looks good so far.
also found the rubbing on the left rear tire. changed to a carrage bolt all is good now.
i have to say, if you can swing it, but a lift(not a jack), picked up a "hanley" lift used for 500
best money we ever spent.
no more crawling around on the floor for THIS fat old man cooldude cooldude
also thanks for the input.
