Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« on: July 27, 2010, 01:10:24 PM » |
Hi all... I am looking for some pictures, and info, on the Cobra light holders. I have never seen them in person, but I saw the last set go for about $350. I am going to try and make a set, that would mount to the original turn signal mounts, if it's feasible - I have a set coming to try it. However, the three pics I have, don't show very well, how the wires are routed. If anyone has a set, either on or off the bike, that can send me a good picture, of the wiring, it would be GREATLY appreciated...my email is: rcav8or@REMOVEsbcglobal.netHere's the pics I have:    Thanks in advance... R
2000 Valkyrie Standard 1999 Valkyrie Interstate 2000 HD Dyna Wide Glide FXDWGRoger Phillips Oxford, IN VRCC #31978 Yeah, what she said...
« Reply #1 on: July 27, 2010, 01:25:20 PM » |
I'm not real sure I understand your question, so if I get off course, just ignore what I write.
The picture with the wires showing, there is a grove in the underside. There is a couple of screw holes or at least one. That is for the wire tie to hold the wires from the lights to the bike out of sight. From there they just go up the fork post and disappear into the headlight.
« Reply #2 on: July 27, 2010, 01:49:59 PM » |
Here's a generic wiring diagram, it works great for me, shouldn't matter whether you have Cobra, Acme or whatever brand driving lights.  The Cobra lightbar you have pictured is just about the coolest one going by the way  -Mike
sheets
« Reply #3 on: July 28, 2010, 05:35:05 AM » |
I've got a few close-up pix of the underside of the light bar. Based on your query, I can't for sure determine what exactly you're looking for. Clarify a little more... I can send a couple pix your way when I get home from work. sheets
MP
North Dakota
« Reply #4 on: July 28, 2010, 05:36:54 AM » |
Set listed yesterday on ebay.
MP
 "Ridin' with Cycho"
Walküre
Oxford, Indiana
« Reply #5 on: July 28, 2010, 07:45:30 AM » |
RJ answered about having a "groove" cut on the bottom, that the wiring is routed in, which is what I am looking for. I can barely make it out in the pics I have, now that I know what I was looking at. If your pics show the groove, a little better, it would be appreciated. I tried changing the size of the pic, but it got too pixelated to show much. Set listed yesterday on ebay.
MP
thanks, just went and looked. Starting out at $280, but the last several I've seen, have gone for around $350. I agree, as was said, that these are really cool, but that's a little rich for my blood - I've bought a half-dozen motorcycles in my life, for less than that.  After I get a set of mounts, I really think I can make one out of aluminum, that will attach just like the original turn signals, that will be similar to the Cobras. Maybe not as pretty, but when buffed and polished, with look very nice. I have some aluminum 1/2" deck material, that should buff and polish out right nicely. I have access to a small mill, that might do it, or I might rough-cut with the plasma cutter. I think it can be done, just have to see if I can be happy with the results - I'm my own worse critic! Thanks, R
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #6 on: July 28, 2010, 07:47:24 AM » |
Williamsburg, KY
« Reply #7 on: July 28, 2010, 07:50:21 AM » |
Yeah, yeah, I need to clean under there sometime soon.
Walküre
Oxford, Indiana
« Reply #8 on: July 28, 2010, 08:13:52 AM » |
WOW!! Exactly what I needed! Not at all as I pictured it, from the description. Thought it was just relieved, not an actual groove. Makes sense, though. Thanks! Makes it a little...er...a LOT more complicated, but still think it's do-able. R
« Reply #9 on: July 28, 2010, 08:15:08 AM » |
Yeah, yeah, I need to clean under there sometime soon.  No one will ever see up under there... unless you take close up digital pictures and post them to the internet  -Mike
Williamsburg, KY
« Reply #10 on: July 28, 2010, 08:16:51 AM » |
Yeah, yeah, I need to clean under there sometime soon.  No one will ever see up under there... unless you take close up digital pictures and post them to the internet  -Mike  Get back to work. Someone may look in on your cubical.
« Reply #11 on: July 28, 2010, 08:18:52 AM » |
 Get back to work. Someone may look in on your cubical.  I have a button I can press for that... -Mike
Jim_Orr
« Reply #12 on: July 28, 2010, 01:05:18 PM » |
WOW!! Exactly what I needed! Not at all as I pictured it, from the description. Thought it was just relieved, not an actual groove. Makes sense, though. Thanks! Makes it a little...er...a LOT more complicated, but still think it's do-able. R Be sure and keep us inform about this project and the more pictures the better. Good Luck
Williamsburg, KY
« Reply #13 on: July 28, 2010, 01:13:57 PM » |
WOW!! Exactly what I needed! Not at all as I pictured it, from the description. Thought it was just relieved, not an actual groove. Makes sense, though. Thanks! Makes it a little...er...a LOT more complicated, but still think it's do-able. R Be sure and keep us inform about this project and the more pictures the better. Good Luck  Ditto that
sheets
« Reply #15 on: July 28, 2010, 06:02:07 PM » |
I believe Specimen answered your question. I ran with it for a number of years. Never did like the look. Sold mine not long ago. Different strokes.... Yrmv,
fstsix
« Reply #16 on: July 28, 2010, 06:17:31 PM » |
If you can buy a set for $350 that would be a good deal, last set i seen new was up to around $750. it's more about safety than anything else. don't forget LOUD air horns!!
