January 31, 2026, 11:29:52 PM
turn signal lens
Topic: turn signal lens (Read 1490 times)
brillo1542
wheaton, il
turn signal lens
July 29, 2010, 10:36:15 AM »
Greetings. I need to change the bulb in my front turn signal. I can't seem to be able to remove the lens. I can get the screw off and the bottom part of the lens will remove slightly from the body, but the top part is held by the plastic loop on the lens. I talked to the service department at the Honda dealer, and the moron there told me to pry it off with a pocket knife!! I went to HDL parts and looked at the picture they had for the turn signal lens, but I couldn't get a good enough resolution to be able to see how to remove it.
I know this is a silly problem with an easy answer, but it has me stumped. Your assistance is greatly appreciated.
PharmBoy
Lawton, Ok
Re: turn signal lens
July 29, 2010, 11:13:07 AM »
If you have the one screw on the bottom of the lense, after the screw is removed, a thumb on the top and a forefinger wrapped around the botton of the lense, squeze, wiggle,& tug should break it loose. Be careful with the little rubber ring on the lense. If all else fails, a little careful prying from the bottom with a small flat blade screwdriver may be in order...JTL
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
