November 21, 2025, 04:13:38 PM *
Author Topic: Works Front spring kit for the I/S ?  (Read 1309 times)
gregk
Retired
Chippewa Falls, wi.
« on: July 31, 2010, 08:55:40 AM »
I have a slow leak on a front shock and figured when when I get around to replacing the seals I'd replace the springs also. Question is though is for you guys that have the I/S is I dont see a spring kit #, only for the GL1500 goldwing 88- is a # 34G. I assume the 88- is up to the current year. The 34G is that the # you guys are using? Are you gus also installing the springs upside down like I hear the Progressives are being installed ? I have the undering that the rear shock from these people is a custom tailored job but I loos to me the front spring kit is a standard spring. I cannot call them till after Mon. but thought I could get a heads up here.
gregk
Retired
Chippewa Falls, wi.
« Reply #1 on: August 06, 2010, 08:04:52 PM »
Ok I see y nobody is responding. I called the company today & they dont have a spring kit for the front forks for us.
