January 31, 2026, 09:57:09 PM
Broken SPEEDOMETER GEAR, 97 Tour
Topic: Broken SPEEDOMETER GEAR, 97 Tour (Read 1528 times)
dennis_obryan1965@msn.com
August 01, 2010, 10:07:56 PM »
After putting front tire back on my 97 Tour I rode the valk about 1/10 mile and speedometer quit working.
Took it home and investigated and found that the male end in the speedometer gear, where the cable slides in was broken off.
I am getting ready to replace the gear but would like to know if this is something that I done wrong so i dont repeat the same mistake.
I have had the front wheel off several times and have never had a problem.
GEAR, SPEEDOMETER
44806-MR1-003 001 $23.02
Re: Broken SPEEDOMETER GEAR, 97 Tour
August 02, 2010, 06:40:31 AM »
Without watching how you do it, it is hard to tell if you did someting wrong.
I will however say this, they are touchy, and any bind will cause failure.....
I have 241,000 on mine and so far, knock on wood, I've only lost 1 speedo head.
That was due to a driver failurer ro comply.....
Red Diamond
Beaumont, Texas
August 02, 2010, 12:37:36 PM »
Quote from: R J on August 02, 2010, 06:40:31 AM
I would think that your home is built out of wood, but with 241,000 miles on your bike, I'd bet you are not home often enough to knock on anything.
