March 18, 2026, 10:39:16 AM *
Author Topic: Horn problem  (Read 1298 times)
jonmako
« on: August 02, 2010, 07:26:45 PM »
I read 12.6 volts at my battery and 11.86 volts at my horn wires and the horn will not work. The horn terminals ring so I believe the horn is good. I did run two wires fromthe battery to the horn and it did not work. Just a bad horn? Any help would be appreciated. 1998 Valk std - original owner.
« Reply #1 on: August 02, 2010, 07:34:40 PM »
If you have a stock horn, it's just a vibrating reed inside. They can corrode and get stuck. Ask here and somebody will have one laying around.
Joe Hummer
Arnold, MO
« Reply #2 on: August 02, 2010, 08:14:29 PM »
I have two sitting on my work bench. PM me your address and i will get one of them in the mail to you. Send your email address and I will key you pick which one.
Joe
1999 Valkyrie Interstate
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: August 02, 2010, 09:05:53 PM »
An excellent time to be thinking 'Air Horns...'.
Fred.
VRCCDS0237
Ratdog
Somewhere out West, Which way did I go?
« Reply #4 on: August 02, 2010, 10:06:37 PM »
Perfect excuse to get a couple of REAL horns lit off from a relay... time to sound like an old Buick when you hit that button.
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
alph
Eau Claire, WI.
« Reply #5 on: August 02, 2010, 10:50:06 PM »
exactly what I did, paid $5 at a junk yard, pulled it out of an old chevy van!!  you can get two sets and bolt them underneath were your kick stand hides.  you'll need to wire in a relay.  use the original wires to activate the relay, then use the contacts of the relay to power the horns.  they're much nicer sounding, my daughters 50cc scooter has the same horn as a stock valk horn!!
« Reply #6 on: August 03, 2010, 04:12:31 AM »
Before ya go to too much trouble make sure you have a good ground.
Horn is always live, ground makes it sound off....
New Haven, Indiana
« Reply #7 on: August 03, 2010, 05:11:49 AM »
Don't waste time making that little squeaker work.  Get a real set of horns as noted in the above posts.
