November 21, 2025, 02:39:05 PM *
Author Topic: Wires under the side cover  (Read 1890 times)
groundpounder01
« on: August 03, 2010, 04:28:48 PM »
Under the right side cover there is two wires covered by a black boot. These wires are feed off of the acc. fuse in the fuse box. They are a green and a white/red stiped colors. My question is are they feeding anything else or do they come from the bow and dead end there? I cant tell as they are wrapped in the main harness.
roboto65
Conroe,TX
« Reply #1 on: August 03, 2010, 04:33:59 PM »
It is an extra 12 volt accessory set of wires so you can hook up a GPS in my case.
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
groundpounder01
« Reply #2 on: August 03, 2010, 06:44:28 PM »
Thats what i figured on.
« Reply #3 on: August 03, 2010, 06:48:24 PM »
Careful what you hook up to them, they're only fused at 5 amps.
MP
North Dakota
« Reply #4 on: August 03, 2010, 07:53:10 PM »
Best bet is to use them to trigger a relay, connected to the battery.
MP
"Ridin' with Cycho"
wilmont kid
« Reply #5 on: August 03, 2010, 08:56:23 PM »
+1  cooldude
ricoman
Sarasota, FL
« Reply #6 on: August 04, 2010, 02:55:35 AM »
good source to feed a relay for lights.
They are "switched"- hot with key on, so the lights will go off when the key is off.
Farther
Quimper Peninsula, WA
« Reply #7 on: August 04, 2010, 01:32:41 PM »
That's where my belly tank fuel pump is hooked up to I believe.
~Farther
Thunderbolt
Worthington Springs FL.
« Reply #8 on: August 04, 2010, 05:06:43 PM »
I used it to trigger a relay that feeds an auxilliary fuse panel.  That way all the accesories go off with the key.
groundpounder01
« Reply #9 on: August 05, 2010, 06:32:39 PM »
Relays are good when they are needed. But to Use a GPS , a fuel shutoff, or even Led lights one is nott needed. It will take alot of led lights to get to five amps cooldude
