November 21, 2025, 04:13:50 PM *
Author Topic: 1986 Goldwing Part  (Read 2551 times)
Hef
Opdyke, IL 62872
« on: August 05, 2010, 08:37:51 AM »
My brother has a very nice 1986 Goldwing which is in mint condition. However, Saturday his fuel pump quit and a new one from the dealer is $182.00. Anyone know where to get one cheaper? I suppose he would even take a used one. TIA. Hef
upjeeper
« Reply #1 on: August 05, 2010, 09:36:18 AM »
ebay?
pinwall?
Daniel Meyer
The State of confusion.
« Reply #2 on: August 05, 2010, 11:21:48 AM »
My buddy James replaced his with a solid state electric one (on his 81 'wing)
CUAgain,
Daniel Meyer
« Reply #3 on: August 05, 2010, 11:28:31 AM »
http://www.jcwhitney.com/electric-fuel-pump/p2005670.jcwx?TID=8014524FT2&zmam=15972153&zmas=21&zm
Hef
Opdyke, IL 62872
« Reply #4 on: August 05, 2010, 01:18:27 PM »
Thanks for the responses. Sounds like the electric would be the way go. Daniel, do you know how that has worked for your friend? Electric can be purchased for $52.00 from JC Whitney.
Bone
« Reply #5 on: August 05, 2010, 02:02:39 PM »
I was riding a 85 Aspencade and kept a booklet of non OEM parts that could be used. Got most of the ideas from the GWRRA tech bd. Of course I have no idea where the book is now but I do remember a posting about using a elec. pump available at Auto Zone and similar outlets. The pump they chose had adjustable pressure which they wanted to set the fuel pressure at stock or lower.
Sorry I can't be of any real help but there are answers out there for a fix.
Daniel Meyer
« Reply #6 on: August 05, 2010, 07:18:50 PM »
I don't know off hand...we got it on the road at an auto parts store (beat walking). He's been running it for near 10 years.
CUAgain,
Daniel Meyer
Hef
Opdyke, IL 62872
« Reply #7 on: August 06, 2010, 04:19:10 AM »
The electric pump sounds like the way to go. Does anyone know what to set the fuel pressure at?
ricoman
Sarasota, FL
« Reply #8 on: August 06, 2010, 04:27:30 AM »
same thing happened to a friend, there are aftermarket fuel pumps that do well
hit a couple wing forums to find what others have used-I did but didn't save the link-anyway, seems there are several alternatives (none are chrome like stock) but 30 bucks was a typical cost.
am surprised the dealer could get one, our local couldn't
Bone
« Reply #9 on: August 06, 2010, 09:17:28 AM »
Found this online;
1986 1200 Honda Goldwing Aspencade.
I bought a fuel pump but am afraid to use it. The pump is 2-3.5 psi, 12 volt and Gal/Hr=28.
The long answer is posted at the bottom of the page.
http://en.allexperts.com/q/Motorcycle-Repair-837/Honda-Goldwing-1986-1200.htm
Daniel Meyer
« Reply #10 on: August 06, 2010, 09:52:32 AM »
Found this online;
Not sure I like that answer...the 86 'wing has carbs, yes? Not fuel injected?
The pressure they list at the bottom...35-40 psi is WAY high for carbs...that's a number for fuel injected. I would think 3 psi is more than enough for carbs...
CUAgain,
Daniel Meyer
tybme
1999 Valkyrie I/S
Topeka KS
« Reply #11 on: August 06, 2010, 11:39:14 AM »
Check out goldwingfacts.com - I know this has been discussed there before.
Also I believe I have a fuel pump off of a 1985 carb. bike - let me know if you're interested in it I'll keep it cheap.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
Challenger
« Reply #12 on: August 06, 2010, 06:00:04 PM »
An after market electric pump is the way to go, but I can tell you from experience that the Facet pump is one noisy critter and will drive you nuts clicking. The electric fuel pumps off the 1100 shadows are about $60.00 cheaper than the Wing pump
« Reply #13 on: August 07, 2010, 03:30:00 AM »
Found this online;
DO NOT use the above 35-40 psi fuel pump.      That is the pump on the 1985&86 Fuel injected SE's that Honda built for 2 years.
Anything over 3# on a carb is almost too much pressure.   Start around 2.5# on an electric pump and go from there.
I'm looking for my substitute link for older Gold Wing replacement parts.   I got it somewhere.  I have an electric pump part # from Advanced Auto if I can find it.   About a $30 pump back then.  Probably around $50 now.
