January 31, 2026, 11:29:44 PM *
Author Topic: Tie downs  (Read 2404 times)
Shotgun
Canadian Lakes, Michigan
« on: August 05, 2010, 04:34:29 PM »
I'm taking the Lake Express ferry from Muskegon to Manitowoc on Saturday.  I have to tie my bike down and as crazy as it seems, I've never tied the bike down before because I just rode it everywhere.  I'm all concerned about tying it down.  I have soft tie downs and plan on using them.  Do I tie them around the fork?  Everyone I talk to says the handlebars are a no-no and I think I agree with that.  I think they tell you to keep the kickstand down and tie down the front.  How far should I compress the shocks?  I don't want to put too much pressure on the stand.  Any advice you can give me will be appreciated.
Red Diamond
Beaumont, Texas
« Reply #1 on: August 05, 2010, 04:52:24 PM »
I have always tied from the handle bars. Don't attach the straps to the upper end of the bars, but rather as close to the risers as they will stay. No problems at all. Compress about 1 1/2" to 2" and tiedown the rear.
Michvalk
Remus, Mi
« Reply #2 on: August 05, 2010, 05:06:55 PM »
And DO NOT leave the stand down!!!!!!
RP#62
Gilbert, AZ
« Reply #3 on: August 05, 2010, 05:13:29 PM »
And don't forget to turn the petcock OFF.
-RP
Red Diamond
Beaumont, Texas
« Reply #4 on: August 05, 2010, 05:18:14 PM »
And if you don't have a wheel chock, tie the front wheel.
Shotgun
« Reply #5 on: August 05, 2010, 05:36:58 PM »
What does turning the petcock off really do?  One of the mechanics I know says that since it is vacuum operated, it really doesn't matter if you turn it on or off.
RP#62
Gilbert, AZ
« Reply #6 on: August 05, 2010, 05:47:05 PM »
The the floats in the carbs bounce around and dribble fuel into the cylinders. Its not completely logical to me but I have seen several instances of hydrolock occuring following trailering without the petcock turned off.
-RP
IamGCW
727 hood
« Reply #7 on: August 06, 2010, 07:26:42 AM »
Take some electrical tape and tape the open hooks so if the strap loosens it won't come off.  Also twist the straps 1/2 turn or more from top to bottom so they won't vibrate to much in the wind.  And finally tape the excess strap to keep it in place.  You don't want a strap tail whipping the paint.  I have tied to the handle bars for years and never had a problem.  I also use six straps. Two at the handle bars, two at the crash bars, and two at the rear frame.  I use a HF front wheel chock that locks in the wheel.  Also I don't use the anchor points for more than one strap.  After you are done shake the bike like you hate it.  It should be one with the trailer.  Fuel off as mentioned.
There were photos some year ago from a Texas rider who showed his methods.  Search the board.
Gil
Shotgun
« Reply #8 on: August 06, 2010, 08:44:03 AM »
How far should I compress the front fork?
« Reply #9 on: August 06, 2010, 09:16:13 AM »
It is very possible to tighten them too much.
Tighten them enough that when you grab your bars you can rock the whole truck and the bike doesn't move.
Don't tighten them so hard that your eye-hooks are wanting to yank out of the stake pockets.
Don't tighten them so hard that the front of your bed is permanently deforming from where the front wheel is
touching it.
stormrider
Kinsey, AL
« Reply #10 on: August 06, 2010, 09:32:24 AM »
I would tie down from the engine guard. Just my 2cent. And never put the stand down when tying down.
« Reply #11 on: August 06, 2010, 09:39:43 AM »
not only turn the gas off, but drain the bowls if possible so theres no gas in case the needle valves bounce.......
« Reply #12 on: August 06, 2010, 11:17:53 AM »
I tie down the front of the bike at the forks, just above the lower triple clamp.  You can't get any more solid than that.  I always tie down the bike vertical, OFF the side stand.
mikeb
vrcc-29271
dansville mi by lansing mi
« Reply #13 on: August 07, 2010, 04:54:12 AM »
-RP
this one has  always made me think. dont the carbs bounce then we are riding them ? i have found that it is more the pressure that the gas splashing around in the tank makes than carbs bouncing
on the 1981 gl1100 my but ride we leave the cap one click loose when stored after it hydrolocked two times after big temp changes do to storms in our area . take gas and put it in a pop bottle then shake it and see if it dont start ito make pressure. or even a gas can sitting in the sun ... more to think about?
i dont care what you ride just ride
mike & kari
mivrcc capital city leader
s.s.d.d.
RP#62
Gilbert, AZ
« Reply #14 on: August 07, 2010, 08:49:46 AM »
I probably shouldn't have speculated why it does it, because I don't understand the mechanism, but I know it does it from seeing it happen several times.  Something to do with the bike bouncing around while the engine isn't running.
-RP
9Ball
« Reply #15 on: August 07, 2010, 09:55:58 AM »
He's taking a ferry boat ride, not trailering in a truck or on a trailer....good advice, but if he can rock that fast boat his name is Clark Kent.....
touching it.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
IamGCW
727 hood
« Reply #16 on: August 07, 2010, 11:53:08 AM »
I usually have the forks compressed about 1".
Gil
Shotgun
« Reply #17 on: August 08, 2010, 05:00:09 PM »
Thanks all.
