November 25, 2025, 04:32:17 PM *
Author Topic: Car tire. Urgent question  (Read 5256 times)
« on: August 07, 2010, 03:58:28 PM »
For a VRCC member in dire straits (not me).
What size tire will fit without the washer mod or nut cage mod?
I need a really quick answer.
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« Reply #1 on: August 07, 2010, 03:59:59 PM »
205 55 16 i put mine on and never knew about the mod.
VRCC#31391
VRCCDS0239
« Reply #2 on: August 07, 2010, 04:09:05 PM »
Thank you for the response.  I'll pass that on.
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #3 on: August 07, 2010, 05:57:27 PM »
I have 205/60/16's on both and had to nut cage mod BOTH of them.  I did not washer mod either.
Jabba
« Reply #4 on: August 07, 2010, 07:29:51 PM »
There are a few 195/60/16 tires available, they should work ok.  Hoser
B
Capital Area - Michigan
« Reply #5 on: August 07, 2010, 11:01:19 PM »
Bigdog99 - do you know how the 205-55-16 affected your rpms ... About due for a back tire & considering the DS. Not sure I'll make it thru the season on my MC tire.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #6 on: August 08, 2010, 03:25:24 AM »
I MAY be wrong, although I wouldn't run with that answer.
  We've done three, from what I see, some bikes need it when another may not. Depends on the individual bike and the accuracy/jig used when built. One Valk was fine with a 205-60-16 Triple tread, no mods needed. My bike needed nutcage when I went to a fatter rear tire (mc tire) 200 series Bridgestone. Then when I went Darkside (regretably) I also had to shim the rear fender, (washer mod.) MY rear fender was off center almost an inch from the factory. I'm sure others can share similiar experiences. Just saying, there all a little differant. The mods are very simple, not time consuming even if there needed.
« Reply #7 on: August 08, 2010, 04:47:53 AM »
The 195 will likely not need the nutcage (or fender washer) mod.... assuming the rider and usual passenger don't go a ton.  A 205 60  (55 is couple mm wider than 60)  may or may not need the nutcage mod (again the weight proviso).... but it is prudent and easy to do.  The fender washer mod is rarely needed.... just for those Valks assembled by drunks or which have been knocked crooked in the back.
Opinion:   Get a 205 60 and do the nut cage mod anyway.
Don't worry, be happy.
mikeb
vrcc-29271
dansville mi by lansing mi
« Reply #8 on: August 08, 2010, 05:49:42 AM »
 Cheesy  205/60/16  same size as a bike tire
      205/65/16 1" taller need nut mod   200 rpm slower on the tac
      195/50/16 1" shorter no nut mod  200 rpm faster on the tac
i dont care what you ride just ride
mike & kari
mivrcc capital city leader
s.s.d.d.
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #9 on: August 08, 2010, 06:54:35 AM »
I have 2 Valks with 205/60/16's.  BOTH needed the nut cage mod.
1 Mans experience does not necessarily extrapolate.
Jabba
bigdog99
Kouts Indiana
« Reply #10 on: August 08, 2010, 06:58:30 AM »
now that i see the other posts, i would have gone with a taller tire. i dropped about 3.5 mpg with the smaller tire.
VRCC#31391
VRCCDS0239
Misfit
Colorado Springs Colorado
« Reply #11 on: August 08, 2010, 07:04:34 AM »
The weight is not a factor. The tire will not bulge in the center where the swing arm is or the top where the nut cages are located. The weight will only effect the tire where it meets the road. At that point it's possible for the tire to sqwat under a heavy load. cooldude
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #12 on: August 08, 2010, 08:45:47 AM »
True, but the weight WILL compress the suspension further, making rubbing more likely because the tire is driven deeper into the fender well.  Take it from a 320 lb rider with a 225 lb passenger.
Jabba
« Reply #13 on: August 08, 2010, 09:39:37 AM »
To me, that seems to be extreme. And you say it is with a 55 profile tire? The cost in mpg's should be less than 1 mpg!
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #14 on: August 08, 2010, 11:18:50 AM »
I have a 205/60/16 Good Year TT, 25,000 w/o any mods on a 98 STD. It has never rubbed and I do ride 2 up often. I am about 200lbs and the women is 145lbs.
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
B
« Reply #15 on: August 08, 2010, 12:57:28 PM »
Thx.
« Reply #16 on: August 08, 2010, 02:04:02 PM »
Jabba
This was my point.
At 180lbs, 13" 440 Progressives, and always solo, I probably could have skipped the nut cage mod, but I did it on both interstates with GTT anyway.
« Last Edit: August 08, 2010, 02:05:44 PM by Jess from VA » Logged
Tropic traveler
Silver Springs, Florida
« Reply #17 on: August 09, 2010, 06:43:35 PM »
[/quote]
Mike.......No way that good lookin' woman of yours weighs 145!!!! Cheesy Cheesy Cheesy Cheesy I hope she doesn't read this forum, you may be in for it!!  2funny Never tell a woman's age or weight. Shocked
Seriously, my experience with a 205/--65--/16 Mich HydroEdge was no mods & no rubbing UNTIL 195 pound neighbor hopped on the back for a quick blast down the road. Immediate rub from the RH side. Clicked the shocks up from 2 to 4 & haven't ridden 2 up anymore. CT coming off soon anyways!
'13 F6B red for Kim
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #18 on: August 09, 2010, 09:22:54 PM »
Care to share the reason?
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #19 on: August 10, 2010, 04:30:09 AM »
R
He doesn't like 'em.  The CT was on the bike when he stole... er bought it.   2funny  Just not a fan of the CT.
Sorry to answer for you TT.  But I think I summed it up didn't I?
Jabba
Mr.BubblesVRCCDS0008
« Reply #20 on: August 10, 2010, 07:19:29 AM »
I've ran a bunch of different CTs in my day and this is the latest and I'm very pleased with it.   http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Potenza+G+019+Grid cooldude
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #21 on: August 10, 2010, 01:54:22 PM »
[/quote]
Your right Eddie, I caught hell and was informed she did not way 145, you would think I would know not to do that at my age.
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #22 on: August 10, 2010, 01:56:54 PM »
I guess she wieghs not ways!!!!
Tropic traveler
« Reply #23 on: August 10, 2010, 07:08:03 PM »
R
I always wanted to try the CT & I bought this Valk with the CT already on. Since I have my beloved '97 Tourer down for {ironic-ly} a new rear Avon {another flat tickedoff} & some needed 100K service I have piled some miles on the '99 with the CT. I have no real problem with the CT but the low speed handling & constant correctioning on our high crowned roads here in FL are more than I want to deal with. I don't care about the cost differential & the better braking along with the good wet weather traction the CT provides are not enough to sway me that way.
I do understand the appeal of a CT on a Valk that some riders like but I guess it just isn't for me. I rode the '99 to work one day then Kim's '98 the next & it was a much more relaxing feeling to be riding the Avon equipped Valk. I do enjoy the reaction the CT gets from some folks when they see the CT on the back though! Grin
I'm sure a more rounded CT that did not have the inherent low speed bad handling the HydroEdge has would make a big difference to me. I searched all over the Internet the other night for a 195/70/16 or a 185/75/16 CT to maybe try but I found nothing in those sizes. Soooo... back to a MC tire I will go!
'13 F6B red for Kim
2qmedic
Simply Awesome!!!
« Reply #24 on: August 10, 2010, 07:56:23 PM »
Hey Eddie, I would like to check that bike out next month!
Any one here have 1st hand experience and know how the 195/55/16 tire handles compaired to the 205/60? (which is what I run now).
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #25 on: August 11, 2010, 04:17:28 AM »
It'll jack your RPM's way up.
Jabba
MP
North Dakota
« Reply #26 on: August 11, 2010, 04:55:42 AM »
R
I had the hydroedge, but changed to a General Altimax in 60 series.  Does not react to the crown and ruts near as much as the hydroedge.  Have ridden a Goodyear TT too, and it is better than hydroedge too. Plus, what air pressure?  When I went from 36# to 28# solo, the tires reacted MUCH LESS to those things.
MP
"Ridin' with Cycho"
Ferris Leets
Catskill Mountains, N.Y.
« Reply #27 on: August 11, 2010, 12:28:48 PM »
I learned a lot about tires while researching my CT.  Ended up with a Fierkin.
The one thing I strongly suggest is going to the manufacturers WEB sites and looking up the exact tire in the exact size.  I found huge differences in the same nominal tire size from brand to brand and model to model.  Some even crossed over so that a 205/55 could have a smaller actual diameter than a 205/60.  Same thing with the widths.
      Seems like the measurements and percents should be real numbers but,  there can be serious deviations.  If you are looking at a tight fit check the actual numbers.
tagalong
Canton, MI
« Reply #28 on: August 11, 2010, 12:50:18 PM »
Jabba
Say Jabba,
What rear shocks do you have? I've got a rub problem with my 205-55-16 Good Year Triple Tread.
The nut cages are gone.  Bolts are reversed, the head is tire side. 440 progressive with 11.5" on center measurements.  Riding one up I'm fine, two up I a rub make on the right side of the tire, the rear bolt seems to be the trouble maker.  I'm 230 and then add the better half.  Do you think 13" progressive will solve the problem?
John S.
Bounty Hunter
States I've ridden in!
« Reply #29 on: August 11, 2010, 01:04:59 PM »
13" shocks will go a long way to solve your problem... even 12.5 might do it, but I would only run 13" shocks on mine, and I have a 29" inseam (5'9").  Even with 13 or 12.5's make sure you get the proper spring rate... probably Heavy Duty for you at 230 with or without the SO.
« Reply #30 on: August 11, 2010, 01:26:54 PM »
Jabba
Say Jabba,
John S.
Bounty Hunter
Could be a washer mod is all you need. Your fender may be off center with regard to the tire.
Tropic traveler
« Reply #31 on: August 11, 2010, 06:06:17 PM »
MP, I run the CT at 36 psi. When I got it the PO said he ran it at 25 psi & I thought that was a bit on the low side so I pumped it up a bit. I'll try backing it down a bit.
I'm sure some of my rubbing is caused by the tire being a 65 series which is a bit taller. Pretty sure the RH nutcage is the culprit.
I did notice there is very little difference in cruising RPM with the 65 as opposed to a MC 180/70. The Hydro Edge does seem to be more "squared off" that any other CT I've seen mounted on a Valk.
All that being said, I would love to try a 195/70/16. If such a thing exsisted it would be tall enough to help with highway RPM yet maybe not so square or prone to rubbing.  cooldude
Ferris is correct! I have seen significant variations in actual tire measurements in same size tire brands. Shocked
Charles, come on down when you get healed up! I may have the MC tire on the '99 by the time you get down this way though.
'13 F6B red for Kim
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #32 on: August 11, 2010, 06:10:08 PM »
I have 13" progressive 440's on the standard, and 13"  custom works shocks on the IS.  I had stockers on the standard though too.
I had to grind 1/2 the depth of the nut off the IS and trim the bolt too.
I never heard of the fender mod till I was done.  We don't bottom now at all, not even on the top of the fender at FULL compression.  And that's rare too.
Jabba
stude31
Topeka,ks
« Reply #33 on: August 13, 2010, 10:22:31 PM »
Well fellas....
I want to thank Willow for his quick post and getting back to me.  I was in the middle of trailering O.P's bike back to my house after his rear AVON COBRA separated.  I had a very small window to figure out what I needed to do to Paul's bike.  We were in a dilema....  It was 4:00pm on Saturday.  No honda shop was open and buddy of mine has a small motorcycle shop who normally mounts my car tires and I had spoke to him to see if he could help me get these folks back on the road....  My window to make a decision was closing and thank you Willow and to all that posted at such a short notice.
Paul chose to go get a triple tread tire and while he was doing that I was tearing apart his bike at my house.  I got him over to the shop and tire was mounted and I was doing the nutcage mod in the mean time.  The were back on the road by 7:30pm.
After they got home Paul said that the tire was rubbing and needed to have the washer mod done.  A bit of information that you guys didn't know was that they were two up on an I/S and were pulling a full trailer and full saddle bags of "stuff".  It was interesting watching them pack their bike up to head out.  Everything had a place.   So with that information yes it was rubbing and as I type this I remember I need to call Paul to explain what he needs to do w/ the washer mod.
But, again....  Thank you willow and all the rest of you that helped out. It was very much appreciated and I knew I could count on someone to let me know "if" and "what" size CT would work...  thanks again.   cooldude
Stude31
P.s... if you ever are in the Topeka,ks area and need a tire or help... check out Extreme Cycle Brian is a great guy and has come through for me and a few vrcc members when it counted...  Great guy, great service.....  (had to make a plug for him... he went out of his way to help and stay late to get Paul on the road.... he sacrificed his dinner date with his wife to stick around and make this happen).
lifguardct
2000 Interstate, 2009 Stratoliner (2007 ZX14 sold)
Southwest Florida
« Reply #34 on: November 30, 2012, 02:43:52 PM »
Any idea how a 195/60R16  would compare?
« Last Edit: November 30, 2012, 02:46:53 PM by lifguardct » Logged
valky1500
MI
« Reply #35 on: November 30, 2012, 06:47:43 PM »
Only hypothetically...
A 195/60/16 is an unrecognized car tire size for a 7.5" rim width.
As it would be close in diameter but much skinnier than the listed car tire sizes above.  Grin
'98 Standard
'01 IS
Yes I pull a trailer
I have taken notice to those who use that word (Precautionary) and abide by it are not only very happy in life...
but they also live long and prosper.  Wink
vanagon40
Greenwood, IN
« Reply #36 on: November 30, 2012, 07:39:38 PM »
Dude,
You would probably get a better response starting a new thread instead of responding to a thread that has been dead for over two years.
But, in an effort to be helpful rather than just critical, check out the Tire Comparison Program on the Shop Talk page.
lifguardct
Southwest Florida
« Reply #37 on: December 01, 2012, 08:57:58 AM »
There are several tires available in this size (Hankook Optimo) shows rim width of 5.5"-7", tread width is 6.3" and diameter of 25.3"
http://www.tirerack.com/tires/tires.jsp?tireMake=Hankook&tireModel=Optimo+H426&partnum=96HR6H426
valky1500
MI
« Reply #38 on: December 01, 2012, 07:30:37 PM »
That might very well be so about tires being that size...  Cheesy
but the point was that those skinny tires won't hold the bead.   Grin
Leastwise, going darkside is one thing but I wouldn't want to try a tire that doesn't match the rim size.   2funny
'98 Standard
'01 IS
CASABROKER
« Reply #39 on: December 01, 2012, 08:31:43 PM »
SP SPORT 5000 Symmetrical 195/60R16 89H BSW Kick ass tire no mods at all.  200 more rpm @ 75mph.
