January 31, 2026, 11:28:57 PM *
Author Topic: A Cautionary note!  (Read 1729 times)
« on: August 08, 2010, 11:03:37 AM »
Some month ago or so someone on the forum wrote about a part in the rear wheel drive assembly which is:
Part #20 (COLLAR B, RR) in the fiche:
http://www.hdlparts.com/fiche_section_detail.asp?section=148613&category=MOTORCYCLES&make=HONDA&year=2000&fveh=3474
The crux of the thread was that it can be installed either end and would not make a difference which way it is installed.
Well, that is absolutely incorrect!
Probably the largest threat is that it is pictured incorrectly in the fiche drawing. The orientation is wrong and should be facing the opposite way.
The part actually pilots into a recess within the pumpkin and will not work it the part is in backwards even though the wheel may still go on and torque down.
Just wanted to mention this!
« Last Edit: August 08, 2010, 11:32:36 AM by Ricky-D » Logged
« Reply #1 on: August 08, 2010, 11:22:47 AM »
Ricky theres no reason to caution....it canot be put in backwards, just cant...only goes in one way
