January 31, 2026, 11:29:40 PM *
Author Topic: tach light  (Read 3057 times)
aphatmat
« on: August 09, 2010, 04:23:58 AM »
Can sombody give me info on tach bulb and how to change it? Thanks, Phatmat Smiley
Mr.BubblesVRCCDS0008
« Reply #1 on: August 09, 2010, 07:23:36 AM »
If it is a standard or tourer remove guage there is a small screw in the back. Remove the screw and the cover will come off and you can get to the bulb then. You can check the bulb number on shop talk page. I want to say it is a 94 but I'm not sure. Hope this helps. Also if the tach light is out check to make sure your running lights work as they are on the same fuse.
aphatmat
« Reply #2 on: August 09, 2010, 07:38:27 AM »
thank you cooldude
CB1
DFW, TX
« Reply #3 on: August 09, 2010, 06:46:29 PM »
I installed some LEDs and this is the result. I love it
white 5 bulb # WLED-X5
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2FcompWLED.htm
ETA, better picture with both lit up..
« Last Edit: August 09, 2010, 06:50:47 PM by CB1 » Logged
Thanks!
Chris
Red Diamond
Beaumont, Texas
« Reply #4 on: August 09, 2010, 09:19:17 PM »
Saw everything but WLED-X5, which one did you install exactly?
Gangman036
Terre Haute, IN
« Reply #5 on: August 09, 2010, 11:14:40 PM »
Copied this some time ago...............hope it helps.
INSTRUMENT LIGHT MOD
How can I add more light to the insturments?
1.   For one, you can put in brighter lights. Added wattage bulbs can be found at your discount auto store. Sylvania makes a bulb (Sylvania # 2825 $1.69 pair ) which has a long looped filament and the insulator is blue in color as opposed to biege. To replace them in your instruments, at the end of the shell on each is a philips screw. Remove the screw and pull off the shell. Simply pull out the light socket and replace the bulb. This will require that you take off your windshield if you have one.On the Speedo, you must remove the knob with a tiny phillips screwdriver inserted into the knob center.
Brighter lights still are inside BLAZER red lens clearance lights #C827R for $1.99 each. More expensive, but brighter (can't find the bulb alone, if you can please inform) and the bonus is you have red lenses for your rear lights if you need them.
This does make the instruments easier to read in the dead of night, but the "disappear at dusk" problem will only be moved to later in the evening....
How about my Indicator lights (Brights, Signals, Neutral)?
To get at the lights, remove the headlight rim. Then, to get the lenses off and have access to the lower boot, you can pull the lenses off with your fingernails, or insert a small flat blade screwdriver under the lenses on top of the headlight and twist to pop them out. You can add brightness by painting the interior of the black rubber lower boots with flat white paint, being careful not to get any paint on the bulbs. Let dry and re-assemble. As MarkT suggests, for more light, turn the entire lower boot around so that they point at you instead of the sky.
CB1
DFW, TX
« Reply #6 on: August 10, 2010, 06:42:13 AM »
look at this link
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fmini-wedge.html
look to the top of the page... WLED Miniature Wedge Base bulbs,  select the tab that says.... WLED-X5, WLED-x5
1 High Flux LED & 4 x 3mm Radially Mounted LEDs, 220 degree beam - These bulbs are Non-Polarized
click see price and buy - I used the cool white WLED-CW5.
« Last Edit: August 10, 2010, 06:47:36 AM by CB1 » Logged
Thanks!
Chris
« Reply #7 on: August 10, 2010, 04:14:59 PM »
Why not just install a #158[3.3w], #194[3.8w] or #168[4.9w] ?? I think the #168 is a bit much and you may get some heat damage..  I think the OEM bulb is about 2w..
