January 31, 2026, 11:28:55 PM
steering bearing
Topic: steering bearing (Read 1752 times)
Valk1520
West Olive, MI
steering bearing
August 11, 2010, 09:18:47 PM »
Does anyone have instructions on how to tighten the steering head bearing nut? I've been noticing some wobble when I have hands off the bars and when the bike is on the lift. the front turns easy and bounces when going to full lock. Any help will be appreciated. Thanks!
tybme
1999 Valkyrie I/S
Topeka KS
Re: steering bearing
August 12, 2010, 09:20:54 AM »
I don't have nay information on tightening he bolt but you may want to do a lookup on replacing the bearings -I have heard that the factory ones can have issues and it is better to replace them.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
August 12, 2010, 09:50:07 AM »
I think what you're noticing is kinda normal.. The bearings need to turn smoothly.. The easiest[ and best] way to check them is to hook a spring scale to one fork and measure the 'tonnage' to just start the forks moving.. It should be 1.75- 2.25 lbs..
August 12, 2010, 10:29:04 AM »
Lift the top plate of the tree and it will be revealed.
Tighten to your hearts delight!
August 12, 2010, 01:51:42 PM »
If you decide you need to adjust those bearings.. Tighten only to 12# on STD/Tour or 9# on IS.. Too loose and not much happens except for maybe a bit of a slight wonder.. Too tight and the bike will hunt like crazy, maybe to point of being dangerous and it will drive you nutz ..
