November 21, 2025, 05:13:12 PM *
Author Topic: Is it the Chicken or the Egg?  (Read 2662 times)
Valkpilot
What does the data say?
Corinth, Texas
« on: August 15, 2010, 02:57:05 PM »
Symptom: Bike won't start in gear with the clutch lever pulled in with either the kickstand up or down.
Diagnosis: Clutch switch is not being activated.
  • Clutch switch works, i.e., makes contact when it closes
  • It's not a worn push rod bushing; it's new.
Root cause question: Is the clutch switch push button worn, or is the clutch lever worn?  The clutch lever has a small divot where the push button makes contact, but I can't remember if it is supposed to be there or not.
There's a work-around in place.  I made a shim out of a piece of Diet Coke can and stuck it between the clutch lever and the switch push button, so everything works as it should for the moment.
« Last Edit: August 15, 2010, 05:38:38 PM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
junior
new hampshire
« Reply #1 on: August 15, 2010, 03:02:01 PM »
and you tested this switch? i.e. multi meter it can still click and not make contact
Valkpilot
Corinth, Texas
« Reply #2 on: August 15, 2010, 03:25:59 PM »
Yes.  And, as I said, with a shim in place between the clutch lever and the switch push button, everything works as it should.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
John U.
Southern Delaware
« Reply #3 on: August 15, 2010, 03:31:02 PM »
The bushing may be worn. This is from Jeff K's generic parts list:
The Honda part Number 2285-MBO-006 is $10
The Suzuki part number 59892-08A00 is $3 and exactly the same part.
Valkpilot
Corinth, Texas
« Reply #4 on: August 15, 2010, 03:35:29 PM »
It's new, as stated above.
« Last Edit: August 15, 2010, 03:37:04 PM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #5 on: August 15, 2010, 05:29:26 PM »
Leave the shim!
Valkpilot
Corinth, Texas
« Reply #6 on: August 15, 2010, 05:37:58 PM »
Leave the shim!
That's certainly the direction I'm leaning!
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
GJS
Today is the tomorrow you worried about yesterday.
Vancouver Island, BC, Canada
« Reply #7 on: August 15, 2010, 06:41:03 PM »
Sounds like you nailed it.
I've got the exact same symptoms @ 60k miles.
Showed up just as my gal and I headed for Utah back in May, the problem disappeared after the first week. I had been thinking it through and had come to the same conclusion you have.
Good to know what worked for you.
Cheers,
Glenn
The tragedy of life is not that it ends so soon, but that we wait so long to begin it.
- W. M. Lewis
Valkpilot
Corinth, Texas
« Reply #8 on: August 15, 2010, 07:01:31 PM »
Cheers,
Glenn
Interesting.  I turned 60k miles right about the time it started giving me problems.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #9 on: August 18, 2010, 04:13:31 PM »
Couldn't resist went outside and looked at mine. Kinda sorry I did found some dirt and spots starting to form on the chrome. But my switch the little arm that comes out is about 3/16 when its all the way out. When it makes contact and allows for starting the bike its out about 1/16 or a little more. Age,water the brake lever arm on the inside wear or the little plastic arm that comes out is not that strong. The screw that anchors it on looks like it may have a little adjustment available but it wont take much that's for sure.
Valkpilot
Corinth, Texas
« Reply #10 on: August 18, 2010, 05:01:53 PM »
Thanks for taking the time to look at your set up and provide me with some details.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Kingbee
VRCC# 576
Northern Illinois
« Reply #11 on: August 18, 2010, 07:12:38 PM »
I had the same problem.  I drilled out the screw hole just a bit over stock size, and allowed me to move the switch just enough to make things work again.
1999 Interstate
2000 Interstate
2004 Rune
Valkpilot
Corinth, Texas
« Reply #12 on: August 18, 2010, 08:38:11 PM »
That's a pretty good work around.
I'm still interested in knowing root cause, i.e., is it wear on the clutch lever or wear on the switch push button?
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #13 on: August 18, 2010, 10:04:11 PM »
With my bike the cause of the same problem was wear in the bolt hole in the clutch lever.  My old lever could wiggle when moved up and down.  The new lever doesn't wiggle, and the clutch switch works properly again.
Cattman
Franklin, IN
« Reply #14 on: August 19, 2010, 04:51:59 AM »
Just changed out my clutch lever with same symptoms. Hole where  the bolt goes thru the lever had worn to a  oval shape and let the lever move away from the switch enough to not engage. New lever and everything works fine.
Valkpilot
Corinth, Texas
« Reply #15 on: August 19, 2010, 04:58:04 AM »
I'll have to check those symptoms.  I know the hole doesn't look oval, but I haven't put a caliper on it to check.  Clearly it wouldn't take much, as a few thousandths of an inch thick aluminum shim fixed things up.
Hmmmm.  If it's loose, maybe if I shimmed the bolt hole...
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Jeff K
« Reply #16 on: August 19, 2010, 05:05:25 AM »
When you say you replaced the bushing are you talking about the bushing on the lever pivot, or the push rod bushing? They can both cause this problem.
Joe Hummer
Arnold, MO
« Reply #17 on: August 19, 2010, 08:18:08 AM »
Hey VP,
I have a set of stock levers at home.  If you are interested in replacing the clutch side, let me know.  Send me a PM.
Joe
1999 Valkyrie Interstate
Valkpilot
Corinth, Texas
« Reply #18 on: August 19, 2010, 07:07:09 PM »
As stated in my first post, the push rod bushing is new.
I've only ever heard about wear in the push rod bushing. I wasn't aware you could replace the pivot bolt bushing, as it is not shown as a separate item on the parts fische.  I guess you have to replace the entire clutch lever.  Thanks for that info!
« Last Edit: August 19, 2010, 07:10:20 PM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Jeff K
« Reply #19 on: August 20, 2010, 05:12:29 AM »
I did some supercharger work on a guys Valk and everything worked fine. The day he came to pick it up it wouldn't start. Luckily I had a spare used clutch lever and swapped it out and sent him on his way.
Valkpilot
Corinth, Texas
« Reply #20 on: August 25, 2010, 07:28:24 AM »
It's the chicken.  Or the egg.  Whichever, JoeValkIS sold me a like-new clutch lever and it fixed the problem.
The new lever not only does not have the divot in the facing plane that meets the switch, but it also doesn't wiggle up and down as much indicating that part of my problem was in fact a worn bushing in the bolt hole.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Jeff K
« Reply #21 on: August 25, 2010, 08:08:05 AM »
Master Blaster
Deridder, Louisiana
« Reply #22 on: August 26, 2010, 08:32:58 AM »
Usually if you add lube pivot bushing to your annual to do list you wont have this problem.  Also if you have replaced the stock levers with nice shiny chromies and happened to save the old levers, you can drive out the bushings, and swap them out, and keep the shine.  Every spring I used to make an its time to lube the pivot levers post after it happened to me once.  Been  Kinda tied up the last couple of years, and got out of the habit.
