February 01, 2026, 12:56:29 AM
Finished wiring in the new trailer.
Topic: Finished wiring in the new trailer. (Read 1681 times)
KW
West Michigan
August 17, 2010, 08:19:21 PM »
I have to say, wiring in the trailer harness went well, but being so anal retentive, I checked and then re-checked everything 4 or 5 times before getting out the wire strippers. Wiring the entire old truck a couple years ago gave us some experience I guess, but cutting into a ‘healthy’ Fat Lady was still unnerving. Also, you just about need an electrical engineering degree to understand the wiring diagram in the Honda Manual. I was able, just barely, to trace back the path of the wires to figure out what did they did. I’m probably just a bit dim witted. Regardless; my son and I got it the first time with no corrections needed and very little cursing. And that my friends is a first!!
RP#62
Gilbert, AZ
Re: Finished wiring in the new trailer.
August 17, 2010, 08:22:30 PM »
Late now, but if you did it using the Honda diagram, you did it the hard way. These are much easier.
-RP
http://www.rattlebars.com/valkfaq/schematics/
KW
West Michigan
August 18, 2010, 06:46:40 AM »
Yea . . . that would have made it a little easier
