February 01, 2026, 12:56:20 AM *
Author Topic: Firing on left side only  (Read 2431 times)
Baldwin
Lavon, TX
« on: August 20, 2010, 07:56:21 AM »
Hey all,
I haven't ridden in few weeks and got her out today to ride to a doctor appointment and she was running a little rough.  I thought that she just needed a few revs to get her back on her feet again.  Well, that didn't seem to help either.  The engine just doesn't sound right.  I feel the exhaust and the left side is hot, but the right side is not.  The tank is full with fresh gas.  I think that I may have a fuel delivery problem to the right side bank of carbs.  Anyone else have any thoughts or experience with this situation?
Appreciate it any help that is provided.
-Jim
Jim Baldwin
2000 Valkyrie Interstate
B
Capital Area - Michigan
« Reply #1 on: August 20, 2010, 08:23:07 AM »
Don't have my computer or cheatsheet (on the road)... Are there separate coils for each side ? I don't know without looking.
« Reply #2 on: August 20, 2010, 08:56:35 AM »
Open a couple drain plugs on those right side carburetors and see if you have fuel to them.. If so, then run a few heavy doses of fuel system cleaner[Sea-Foam] thru it and see if it clears up..  As far as the electrical system,, if one side is firing the other will too..
Baldwin
Lavon, TX
« Reply #3 on: August 20, 2010, 11:14:59 AM »
Thanks for the replies.  I picked up some SeaFoam today and will check the bowls on the carbs later this afternoon to see if they are getting gas.
Jim Baldwin
« Reply #4 on: August 20, 2010, 11:22:20 AM »
Put ALL of the can into the full of gas tank.
Ride it for about 5 miles
Park it in the garage till tomorrow,
give the SeaFoam a chance to  work.
Next day ride it as much and as far as you like.
That should clear it up.
Oh, the 5 mile ride, try to stay in the idle side of the jets.
NO hard twist of the throttle
« Reply #5 on: August 20, 2010, 11:31:10 AM »
Try Gumout Regain. Used it last month and got 4-5 more mpg.
Baldwin
Lavon, TX
« Reply #6 on: August 20, 2010, 11:33:40 AM »
All 16 oz of it?  Is there any risk to the motor running it on only 3 cylinders?
Jim Baldwin
« Reply #7 on: August 20, 2010, 12:14:25 PM »
If its not fuel, it could be electrical.......I wouldnt suspect coils, there are three and all of them cross sides.  BUT.....there are two ignition pulse generators that feed off of the trigger wheel.  If one of them stopped working for some reason it would take out a whole bank.......just thinking out loud
« Reply #8 on: August 20, 2010, 04:59:38 PM »
     Do you have a Dyna 3000? Buddy of mine had one take a crap on him on the way to                           Daytona  a few years back. Only hitting on the right side if I remember correctly. Put the stock ignition box back on and all was well. Just a thought.
Baldwin
Lavon, TX
« Reply #9 on: August 20, 2010, 05:05:20 PM »
Nope, no Dyna 3000.  All stock except for some chrome.
Jim Baldwin
RP#62
Gilbert, AZ
« Reply #10 on: August 20, 2010, 05:34:53 PM »
Don't think it works that way.  Usually with two pulse generators, one is used to calculate RPM and the other determines crank position.  I'd be willing to bet that if you disable either one, it wouldn't run at all.
-RP
Grungie
Quinlan, Tx
« Reply #11 on: August 21, 2010, 06:09:14 AM »
the left timing belt may be the problem. won't hurt to look. Embarrassed
If its not Wet and Cold I'am a gona RIDE!
Grungie
Quinlan, Tx
« Reply #12 on: August 21, 2010, 06:13:45 AM »
OK, so I should have said right timing belt. oops Undecided
« Reply #13 on: August 21, 2010, 12:39:29 PM »
I don't think five miles of riding is enough to get the additive into the float bowls of the carburetors.
It may have gotten a little into the fuel galleries.
If it's mixed good in the tank you can drain the float bowls (each one) to accomplish this.
With the stock petcock there is a whole other procedure to accomplish the same!
Ride for 20 or 30 miles may do it!
Baldwin
Lavon, TX
« Reply #14 on: August 22, 2010, 09:28:38 PM »
Well, I'll be taking her to the shop on Wednesday.  Thanks for all the advice.
Jim Baldwin
« Reply #15 on: August 23, 2010, 07:23:53 AM »
There was some other thread where a MCB had reported a similar problem only to find he was riding around with all three intake risers (on the same side) loose, at the inside of the risers where it was not evident to the rider.
Pretty recent thread if I recall.
