March 07, 2026, 08:39:23 AM *
Author Topic: Fooey... paint job on fairing messed up...  (Read 3872 times)
« on: March 25, 2009, 06:38:15 PM »
The paint sagged around both the front fasteners:
Daniel the painter says he'll have to totally redo all the white part.
The consensus is that the paint wasn't cured enough to withstand the
torque I introduced when I snugged down the nut - there's a rubber washer
beneath the stainless one.
I'm going to look for a pin-and-clip kind of thing to hold it there next time, instead of
a nut and bolt. Or, if I can't find something suitable, perhaps I'll use blue loctite
on the nut-and-bolt and barely tighten it.
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #1 on: March 25, 2009, 07:04:14 PM »
Maybe a bushing that fits through the hole on the faring for the bolt to tighten to.  The rubber washer would keep it snug.  The OEM windshield has that kind of fastener.  Keeps things secure, but allows some movement.
Big IV
Iron Station, NC 28080
wow
« Reply #2 on: March 25, 2009, 07:35:57 PM »
I'm not even sure I would have noticed that wrinkle in the paint. Better eye than I have.
"Ride Free Citizen!"
VRCCDS0176
Madmike
Campbell River BC, Canada
« Reply #3 on: March 25, 2009, 07:44:47 PM »
If you resort to Loctite you may want to try the Green stuff, it is for low torque applications, adjusting screws etc.
If you do the pin route are you thinking off using a longer pin and Mae West clip and spring loading the pin to hold it in place??
« Reply #4 on: March 26, 2009, 03:07:31 AM »
Thanks, I didn't know about green loctite...
I am imagining something like this for the pin:
Danny sez that after a few hot weeks of the weather we'll soon have the paint will
cure all the way and the bolt can be tightened.
« Reply #5 on: March 26, 2009, 03:09:02 AM »
If the hole in the fairing is big enough for the bolt and a bushing, that's a GREAT idea...
Kingbee
VRCC# 576
Northern Illinois
« Reply #6 on: March 26, 2009, 06:53:53 AM »
How about a larger, painted-to-match washer.  When I did my Hoppe, I had the painter paint the washers to sort of make them go away.
1999 Interstate
2000 Interstate
2004 Rune
Kingbee
VRCC# 576
Northern Illinois
« Reply #7 on: March 26, 2009, 06:57:09 AM »
Those bolts are under a LOT of stress when going over bumps, as the fairing is heavy.  You'll never get them tight enough, and soon enlarge the holes and crack/ruin the fairing.
1999 Interstate
2000 Interstate
2004 Rune
« Reply #8 on: March 26, 2009, 07:01:51 AM »
I'm about 100 % sure that pin deal will be a bad idea. It will not pull tight as Kingbee pointed out  and the rattle alone would drive you insane.
« Reply #9 on: March 26, 2009, 07:09:23 AM »
Yeah, how big are they, I can't see them?  Grin
« Reply #10 on: March 26, 2009, 07:22:11 AM »
I got " STAR " washers at East Tennessee Goldwing they was about .75 cents .
« Reply #11 on: March 26, 2009, 07:31:18 AM »
So you got something like this behind the  chrome/stainless washer that can be seen?
« Reply #12 on: March 26, 2009, 07:45:24 AM »
Not like that....Its a washer with a " Star " stamped into it  Smiley  I can't find a good picture to post that shows it.
Kingbee
VRCC# 576
Northern Illinois
« Reply #13 on: March 26, 2009, 08:26:47 AM »
I guess that's the point of painting them to match.....
1999 Interstate
2000 Interstate
2004 Rune
Madmike
« Reply #14 on: March 26, 2009, 10:06:34 AM »
Lots of guys use these on the trunk racks on the Goldwings to spread the weight of the rack legs over a larger area so that the trunk lid doesn't crack.  They are similar in size to a fender washer but have a better finish and are decorative.
Here is a link strictly so you can see the washers - no commercial endorsement
http://www.chromeworld.com/index.cfm?fuseaction=catalog.prodInfo&productID=499&categoryID=123
http://www.wingstuff.com/pgroup_list/supplies/619_goldwing_Star_Washer_Mounts/des/
You may want to look at Firestone mounts if vibration or rigidity is a problem.  They are a rubber mount that comes in various configurations and provide a stud or threaded hole in each side for fastening.  A common application is on powersaws between the engine and the handlebar to isolate the vibration.  If you have a Husqvarna or Stihl dealer close by go to them and ask to see a mount for a chainsaw motor, they will have them at a reasonable cost.
Couldn't find a picture but here is a link to the manufacturer http://www.pacific-molded.com/firestone.html
Go to the site and download the PDF catalog and you can open that to see the mounts, they are about an inch long, 7/8" in diameter and have the threaded holes or attachments on each end.  I have used these for mounting A/C units on loaders and for guage and control panels that are engine mounted.
« Last Edit: March 26, 2009, 11:01:39 AM by Madmike » Logged
