February 01, 2026, 12:56:26 AM *
Author Topic: Sudden Clutch problem.  (Read 1950 times)
jad
N. Atlanta Ga
« on: August 21, 2010, 11:56:07 AM »
A few weeks ago my clutch lever suddenly won't pull in to the grip.  It goes  to about a finger width away from the grip.  I tried bleeding it  but realized that it wasn't going to help any.
It never made any noise or acted strange until it acted this way.
Does anyne have a anything constructive to add here?
As usual, I really appreciate any and all comments.
98 Burg & Cream Tourer
« Reply #1 on: August 21, 2010, 12:18:15 PM »
You should investigate further to determine what the problem is. Simplest things first!
(1) It could be the lever itself.
(2) It could be the master cylinder internals.
(3) It could be the clutch.  If so there are a few things that could be responsible.
Investigate, investigate, investigate!
PhredValk
Edmonton, Alberta, Canada
« Reply #2 on: August 21, 2010, 12:41:55 PM »
I'd take it apart. Remove the lever and pushrod to see is something has lodged in there, Like a rock chip or splinter of wood from the road.
Fred.
VRCCDS0237
Rio Wil
« Reply #3 on: August 21, 2010, 08:47:52 PM »
Sounds like a classic case of rivit'itis, but check the handle bar mechanics first.
six2go #152
Ft. Wayne, IN
« Reply #4 on: August 22, 2010, 07:30:00 AM »
10 - 4 on the rivit'itis. That's the way mine acted, plus it was almost impossible to find neutral and the bike would "creep" at a stop with the lever pulled in(to the hard stop). Complete new clutch = no more problems.
Jeff K
« Reply #5 on: August 22, 2010, 05:23:33 PM »
I vote... Damper plate failure...
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #6 on: August 22, 2010, 06:20:17 PM »
Ditto on the rivits, Mine went out when I was 1200 miles from home, I rode it back on I75 and rebuilt the clutch when I got home
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
