March 18, 2026, 08:16:22 PM *
Author Topic: Brake pads  (Read 1801 times)
Hoghead
Kilgore, TX
« on: August 22, 2010, 07:46:35 AM »
Time to replace the stoppers on the old girl. My IS has 8500 miles and the rear brakes are worn out. I have only ridden it 2500 of those miles. Is this normal or did the previous owner have an heavy foot. I don't use my rear brake heavy unless needed. I would like some suggestions on the best shoes for her. You know with a lady its all about the shoes. laugh
2000 I/S. Coronado Blue & Silver
1984 V65 Magna. Really Fast Black
E. Texas Patriot Guard Rider
« Reply #1 on: August 22, 2010, 07:53:47 AM »
Sounds like someone had a heavy foot on the rear.
Some people use the rear only unless it is a pucker factor type stop.
Pads,   EOM on EOM rotors.
Several on the board had squeaking problems with after market pads.
« Reply #2 on: August 22, 2010, 09:06:51 AM »
I use to wear out rears at 19K. I changed my braking style and now go 30K on the rear and 40K+ on the fronts. Now have 114K and the next fronts will need rotors too. Probably going with GL1800 rotors and OEM pads.
New Haven, Indiana
« Reply #3 on: August 22, 2010, 12:18:59 PM »
After past experience with aftermarket, i think that OEM works best!  No squeals or rattles.
« Reply #4 on: August 22, 2010, 12:27:23 PM »
Some good reading here.
http://www.webbikeworld.com/Motorcycle-Safety/braking-tips.htm
Use Honda pads.
« Reply #5 on: August 22, 2010, 01:11:20 PM »
vesrah, ferodo or OEM. Vesrah makes most of the OEM pads for the manufacturers. OEM pads are HH rated as are my vesrah pads.
search my name in the tech section, I have posted some other info and links.
Cruzen
Wigwam Holbrook, AZ 2008
Scottsdale, Arizona
« Reply #6 on: August 22, 2010, 04:41:10 PM »
I have used EBC HH for the past 15 years or so on all by bikes.  In my experience they stop faster than OEM and wear about the same.
The trip is short,
enjoy the ride,
Denny
PAVALKER
Pittsburgh, Pa
« Reply #7 on: August 22, 2010, 04:49:26 PM »
OEM with OEM Rotors.....   cooldude   Others have experienced more noise, dust and even less wear with other than stockers....
Some may use the rear brake a little more for slow maneuvers... the "friction zone" as outlined in Ride Like a Pro....
John
« Reply #8 on: August 22, 2010, 05:02:52 PM »
Absolutely but certainly not enough to wear the rear pads faster than the front. Unless one is riding around Wally World  parking lots for kicks
lacon
« Reply #9 on: August 22, 2010, 05:05:48 PM »
The rear caliper floats on 2 pins.  If these pins get cruddy, the result can be dragging pads & a shortened life for them.
Something else to watch for when putting on new rear pads is that the interstate does not use the white plastic spacers which the Standard & Tourer need.  The last OEM Interstate pads I bought had the spacer pads included.  I double checked the part #'s - they were blister packed as interstate pads.
For what it's worth, I have a Standard, but buy the Interstate pads & move my old spacers over to the new pads.  Saves 8 or 10 dollars if I remember right.
« Reply #10 on: August 22, 2010, 05:26:14 PM »
... Unless one is riding around Wally World  parking lots for kicks
Oh, so you've been to Kansas?   Grin
Dragonryder2
« Reply #11 on: August 24, 2010, 10:23:58 AM »
Good Heavens, I have 60,000 on my bike and haven't replaced front or rear pads.  Something must be wrong with the way I ride.
Hoghead
Kilgore, TX
« Reply #12 on: August 24, 2010, 11:03:35 AM »
Doesn't sound like anything wrong with that Dragonryder.
sounds like your always on the go. I think the brakes were sticking even though the rotors don't show any evidence of it. I will find out when I change them out. I'm going with the Honda pads. The EBC's were about the same price as Honda.
