February 01, 2026, 12:55:28 AM *
Author Topic: Shock spring compressor....anyone???  (Read 1777 times)
« on: August 22, 2010, 11:57:10 AM »
Trying to compress the shocks to replace the HD springs with Std., but not having much luck. I can come close, but can't seem to get enough tension off the keeper so I can remove the top cup and the spring. Has anyone ever done it and what method did you use? I have a set of spring compressors for automotive struts, but they're much too big for this job. I looked around town but haven't found any tool store that has anything but automotive stuff.
« Reply #1 on: August 22, 2010, 01:48:28 PM »
To which shock absorbers are you referring?
Cliff
Manchester, NH
« Reply #2 on: August 22, 2010, 02:47:08 PM »
I have the spring/shock compressor sold by progressive, used it on my 440's.  I now have works.
VRCC # 29680
« Reply #3 on: August 22, 2010, 03:12:54 PM »
I have HD 12" Progressive 412's on the Valk. I have about 700 miles on them, the HD springs are too harsh a ride for my taste so want to change over the Std. springs. Guess I could get the compressor from Progressive, just thought someone on here may have a "homebrewed" method like we often do in other areas we talk about.
Bugslayer
Lubbock, Texas
« Reply #4 on: August 22, 2010, 07:28:01 PM »
Have you tried changing the shocks with the bike on a lift? I've taken my shocks off several times (while removing the rear wheel), and I've never had to compress the shock. Just a thought.
« Reply #5 on: August 22, 2010, 07:41:18 PM »
I don't have a problem changing the shocks, they come off real easy. It's the springs on the shocks I'm talking about. Altogether a different story, changing the springs on the shocks. I finally ran across a post on a VTX1800 site where the guy made a tool similar to the Progressive tool...except his cost less than $5 and a couple hours of his time. Over the next couple days I'll be pulling together the scrap metal needed to make one, I have plenty of time.
« Reply #6 on: August 22, 2010, 07:47:18 PM »
I sent in my 440 shocks to Progressive and they swapped the light duty for the HD springs for $15 per shock and they provided the springs.  They kept my light duty springs and returned them to me with the HD's.  I had to pay shipping both ways, but it was worth it for me and I didn't have to compress the springs myself.
Hay  Cool
« Reply #7 on: August 22, 2010, 07:55:22 PM »
They offered me the same deal, with shipping I'd have close to $50 invested in just a spring change. Being the cheapskate that I am, I'll put together the homemade unit I mentioned above.  Wink
It works exactly like their $36 unit.
Bugslayer
Lubbock, Texas
« Reply #8 on: August 22, 2010, 08:50:00 PM »
My bad... I misunderstood your problem.
Good luck with your project.
