November 21, 2025, 05:17:01 PM *
Author Topic: I saw these lifts at Sturgis  (Read 1905 times)
BamaDrifter64
Athens, Alabama
« on: August 25, 2010, 06:17:03 AM »
http://www.pitbullmotorcyclelifts.com/
I saw these lifts at Sturgis and was impressed with them.  Very heavy duty, 25" lift height, and with turntable, can rotate the bike 360 degrees.  The price is not that high if you compare it to the price of a table lift and it doesn't take up as much room.  They have both hydraulic and air models.  I have no association with them, just thought some of you may be interested.
Dave
3W-lonerider
Shippensburg Pa
« Reply #1 on: August 25, 2010, 01:59:09 PM »
i had one and absolutly loved it..but sold it when i triked mine out..they will not work with trikes..to much weight in the rear.
BamaDrifter64
Athens, Alabama
« Reply #2 on: August 25, 2010, 02:40:47 PM »
Did you have any problems using the lift with your Valk?
« Reply #3 on: August 25, 2010, 03:06:24 PM »
After Dunwell went out of business, Pitbull became the only high quality lift. They use cold rolled steel instead of mild steel which flexes too much. Sears has one which I've used and it's a great lift but not in the Pitbull class. But still a stiff strong lift. http://www.sears.com/shc/s/p_10153_12605_00950191000P?mv=rr
Sodbuster
« Reply #4 on: August 25, 2010, 08:52:09 PM »
I bought a pitbull and really like it .... I used a strap and jack stands for added insurance but prolly wouldn't have needed too. It has no problem lifting the Valk and I use the permanent adaptor by the side stand.
VRCC # 30938
3W-lonerider
Shippensburg Pa
« Reply #5 on: August 26, 2010, 03:33:20 AM »
no problems lifting the valk at all..and never strapped it down..i used other lifts when i went to other peoples houses to work on their bikes..and let me tell ya..i wished i had taken my pitbull with me..those other lifts..scary at best.
