November 21, 2025, 06:33:03 PM *
Author Topic: Fuse for break light  (Read 1431 times)
Heinno
« on: August 27, 2010, 12:32:43 PM »
 My break light suddenly died - both front and back breaks, so I guess it is the fuse, not the switches.
Where is the fuse located? (The headlights and indicator lights are still working)
Any advice welcome!
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: August 27, 2010, 12:46:06 PM »
Fuse box is under the right side cover.  Under it you will find a black cover marked FUSE.  Be careful removing the side cover.  Pull the back end off the stud gently then remove the front loop from the center cover tab.  If you force it you'll break the tab and you'll be back here asking how to fix it.
Marty
Heinno
« Reply #2 on: August 27, 2010, 12:54:03 PM »
Thanks Marty
I only see the engine fuse - will look again, how does this (BREAKLIGHT)fuse look?
(Also, I have checked the bulb - it is not blown - works fine)
Heinno
« Reply #3 on: August 27, 2010, 01:26:01 PM »
Marty
Thanks, I found it - it was the small size of the fuse box that got me - I thought the fuses would be regular (car) size - hence I did not open the small box. But I looked again and opened it - and there they were - was the top 10 Amp one. Replaced - the problem is fixed - thanks!
Hein
X Ring
« Reply #4 on: August 27, 2010, 06:23:49 PM »
Anytime Brother.  That's what we're here for.
Marty
