November 21, 2025, 06:32:59 PM *
Author Topic: new here. vacuum line question  (Read 1447 times)
supermanprime
« on: August 28, 2010, 08:40:20 AM »
I have been workin on my friends 2000 valk, it was in an accident and we needed to do an engine swap. i figured out most of the hoses through here, however I am still unsure on the tank vent tube. from what I have read here the line that comes from the #6 carb goes into the thin opening on the petcock right? where does the tube that goes into the rear center underneath the tank go or come from? my friend just digged into it without taking note where the lines came from and went. thank you. the green str goes into the petcock fer fuel, the blue strs into the airbox , the clear one isn't showin  but I know that already. the red ones go into the 2 holes in the chrome bracket(do they just hang there?) the one from #6 carb isn't showing in this pic. i just need to know about the rear vent on the tank, also do the red stars just hang?or do they connect to something, thank you, great boards by the way.
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: August 28, 2010, 08:59:19 AM »
The tank vent line goes behind the center cover.  There is a Tee halfway down the line.  The perpendicular leg doesn't have a tube attached.  It's there in case the lower tube get's plugged.
Marty
supermanprime
« Reply #2 on: August 28, 2010, 09:07:49 AM »
so does the 2 lines from the t go 1 into the petcock and the other to the little nipple on the back part of the tank? thanks fer the quick reply.
Mr.BubblesVRCCDS0008
« Reply #3 on: August 28, 2010, 09:51:49 AM »
one from #6 intake to petcock small port facing forward on vaccum side.The one from center rear of tank goes behind center cover has a T in it nothing on one barb other barb has hose going to bottom of bike to vent tank. T is to keep it from picking up water when riding in the rain.
supermanprime
« Reply #4 on: August 28, 2010, 11:02:03 AM »
thanks again fer the speedy reply. so just to make sure i got you right. the one from the rear vent nipple on tank ands up in a t going to the back that hang under neath with the clear tube and the others right? how many tubes should be hanging under with the clear tube?
