February 01, 2026, 02:22:53 AM
U Joint replacement Where to purchase??
Topic: U Joint replacement Where to purchase?? (Read 2267 times)
Hotrodwing
Clarks Summit PA
August 30, 2010, 11:24:15 AM »
Liiking for a new Unit and HDL says HONDA has them on back order till 2-11. WHAT THE %#@??? I placed an order back in July. Does anyone know where I can get a new unit from ??
Re: U Joint replacement Where to purchase??
August 30, 2010, 12:21:34 PM »
yep! Me too!
Same thing, I ordered it this past June and still it is on back order.
You can order a Goldwing u-joint and they are the same thing. I didn't bother, figure the same with them.
Luckily mine is still in good shape, at least I hope it is. Probably got 20k miles on this new one.
I just wanted to replace the u-joint along with the newly rebuilt rear end and do the whole drive line.
Guess that wont happen now.
Spirited-6
Nicholasville, Ky.
August 30, 2010, 01:43:52 PM »
DAMN, I would hope so. If not , I`m in trouble. How can you wear out a U-JOINT in less mileage ???
Some body rides "VERY HARD".
Spirited-6
Hotrodwing
Clarks Summit PA
August 30, 2010, 02:11:45 PM »
Mine is also ok I just wanted to replace it,but it still sucks that there on back order
f6power
Round Lake Beach,IL
August 30, 2010, 02:45:04 PM »
I got mine from cheapcycleparts.com begining of July.But I don't know if they have any left.
August 30, 2010, 08:03:57 PM »
Try calling a trike shop. When they build a 1500 wing, they save the U joint. It isn't used in the trike kit. I installed a low mileage U joint in a friend's Valk nearly 2 years ago and he's had no problems. If you want to contact my local trike shop, they would ship one out for you. D&D Discount Motorcycle. 480-Seven-Three-One-9003
Reply #6 on:
August 31, 2010, 04:34:05 PM »
Cheapcycle parts has none, nor does HDL... Ron Ayers?
Hay
