intake runner vacuum lines cut on 1,5,& 2
Started by Doc X, Thu 02, Sep 2010, 20:36:54
Previous topic - Next topic
Doc X
Why are the vacuum lines to the base of the intake runner cut and plugged on cylinders 1, 5, & 2?
I found that with the spark plug covers off.
doc X
because those ports are not needed/used for anything.......if they werent plugged theyd be "vacuum leaks"
Doc X
Colin
Quote from: Chrisj CMA on Thu 02, Sep 2010, 20:51:12
Not quite accurate you use there ports if you want to sync your carbs but in normal running they don't need anything connected to them, make sure the caps are good and not perished / cracked though.
Colin
VRCC Espana
My Bumble Bee re-build
shortleg
  Also means that they only had to make one mold for
the runners and one part number.
         Shortleg[Dave]
Farther
Quote from: shortleg on Fri 03, Sep 2010, 05:52:26
         Shortleg[Dave]
That would seem logical but does not usually apply in my opinion.  Otherwise I would think that there would be one ICM, one set of carb springs, one fuel tank, etc.
~Farther
shortleg
  But still allows them to use parts across the different models.
             Shortleg[Dave]
