February 01, 2026, 07:05:25 AM *
Author Topic: Temps  (Read 4016 times)
RP#62
Gilbert, AZ
« on: September 03, 2010, 05:33:12 PM »
Rode the bike to work today.  It was nice this morning - about 82°F on the way in at 5:45.  Coming home was a different story.  I've got a digital temp indicator on my bike and I can toggle between air temp and coolant temp.  When I started the bike up to come home, the air temp indicator was showing 118°F.  I was thinking, well, its been baking in the sun all day, we'll see what it does when there's some airflow over it.  Sure enough, a soon as I got it up to 40, the temp plummeted to 114°F and stayed there.
By the time I got out on the freeway, it stabilized at 117.5 and stayed there the rest of the way home (20 miles).  At 60-70 mph indicated, coolant temp was 188°F and oil temp was 214°F.  If there was water in my oil, it ain't there no more.  Though I'd post for those interested in temps.
-RP
iliveforcurves
Proud owner of a 2003 Valkyrie Standard
Buchanan Dam, TX
« Reply #1 on: September 03, 2010, 05:42:41 PM »
Does your oil temperature go down when you're idling for a while, like at a long red light?  I've got one of those meat thermometer dipsticks and the oil temp actually goes down when stopped and there isn't any airflow through the radiator.  It seems counterintuitive to me, I thought the coolant temp would be climbing and so would the oil.
Live to ride, ride to...uh, what was the question again?
2007 Kawasaki Ninja 500
2007 Kawasaki Ninja 250
1978 Yamaha SR500 (not running)
RP#62
Gilbert, AZ
« Reply #2 on: September 03, 2010, 06:15:09 PM »
Yup, sitting at idle after a run, warm day, coolant temp will go up and the fan will come on.  Oil temp will come down about 5°.
john
tyler texas
« Reply #3 on: September 03, 2010, 07:59:42 PM »
its a candy thermometer ...     coolsmiley
vrcc # 19002
Pete
« Reply #4 on: September 04, 2010, 10:23:26 AM »
The oil is under less stress and lower flow at idle, temp should go down.
JetDriver
Columbus, OH
« Reply #5 on: September 04, 2010, 11:11:23 AM »
-RP
I've not seen those.  You have more info?
« Reply #6 on: September 04, 2010, 08:10:48 PM »
How could you read those small digital readouts with all that sweat in your eyes.
RP#62
Gilbert, AZ
« Reply #7 on: September 04, 2010, 08:16:56 PM »
-RP
I never could find any I liked so I built my own.  Voltage on the left and temps on the right.
-RP
RP#62
Gilbert, AZ
« Reply #8 on: September 04, 2010, 08:19:26 PM »
It wasn't easy.  I had to duck in behind the radiator to cool off.
I am ready for summer to be over.
-RP
JetDriver
Columbus, OH
« Reply #9 on: September 04, 2010, 08:24:14 PM »
Very well integrated- looks nice!
« Reply #10 on: September 05, 2010, 04:20:18 AM »
Any tips on a instal or ya keeping it a secret?  Wink
Colin
My old job
Orba, Spain
« Reply #11 on: September 05, 2010, 06:29:34 AM »
RJ wanna make some more? I'd be up for a pair.
Colin
VRCC Espana
My Bumble Bee re-build
RP#62
Gilbert, AZ
« Reply #12 on: September 05, 2010, 08:57:31 AM »
I've been thinking about it.  I just made a set for my wife's bike - well, machined the housings anyway, I've got to order the digital displays and solder up the circuit board.
Installation - I put one sensor on the underside of the cobra light bar so that its away from the engine heat an in the airstream below the light and the other sensor is in the thermostat housing.  Both feed into a relay in the indicator housing and I use a micro toggle switch on the right switch housing to toggle between sensors.
-RP
JetDriver
Columbus, OH
« Reply #13 on: September 06, 2010, 09:48:10 AM »
RP~  You interested in putting together display units and wiring harnesses for those of us (ok, me) who aren't as knowledgeable?  Also, directions for making clean cuts in the speedo/tach brackets to hold the displays?  It'd be worth a few dollars to me.
dago mooserider
San Diego, CA
« Reply #14 on: September 06, 2010, 09:11:28 PM »
+2! My pops and I have have both considered the motosens gauges but price is an issue and I am a "less is best" kinda guy. These are discreet and sweet. Hook it up and make a few bucks off us valkaholics.  cooldude
RP#62
Gilbert, AZ
« Reply #15 on: September 07, 2010, 05:48:23 AM »
Once the temp in my garage goes below 100°, I'll have a look.
John U.
Southern Delaware
« Reply #16 on: September 07, 2010, 08:09:38 PM »
+3  Those are very cool.  cooldude
Paul-M
Northern Vermont
« Reply #17 on: September 17, 2010, 06:05:24 AM »
+4 ... I'd love a set as well. They look great! Fantastic job!!  cooldude  cooldude
Paul Martin
2000 Valkyrie Tourer
2001 Valkyrie Standard (sadly retired)
2qmedic
Simply Awesome!!!
« Reply #18 on: September 17, 2010, 01:38:51 PM »
Where are we at? +5
I'm interested Smiley
« Last Edit: September 17, 2010, 06:45:14 PM by 2qmedic » Logged
Airetime
Anacortes, WA
« Reply #19 on: October 01, 2010, 08:43:39 PM »
-RP
It is easy to just grab the face of the dipstick and screw it in after using it "BUT" that is wrong way to use it as it may change the calibration.
If you own one and have been screwing it back in by grabbing the face, rather than using the nut to tighten it, it probably will need recalibrating, at least check it against another to make sure that it is still reading correctly.
How to test it correctly is also in the link.
They can be recalibrated by simply turning the hex nut. The link below shows how. Hope that helps!
Easy Re-calibrateing the Tel Tru Stick
http://www.teltru.com/cats/01204001/01204001.pdf
