February 01, 2026, 03:52:19 AM
Headlight reay
Topic: Headlight reay (Read 1549 times)
Stitch_in_La
Bentley Louisiana
Headlight reay
September 04, 2010, 07:12:39 AM »
Not much luck with the searching, slow internet connection patience level very low. Started the bike yesterday, highbeans were on, then they went out. Low beams still work, little blue high beam indicator is on. I'm thinking high beam relay, honda wants $45-$55 for it is there a direct fit replacement? Am I on the right track? Oh yeah '99 Interstate.
Thanks guys!
Chuck
shortleg
maryland
Re: Headlight reay
September 04, 2010, 08:57:51 AM »
I have never looked at the relays on my Interstate but have
installed some.
Do they look like the ones we use for other things ,lights ect?
If so maybe you can use what we use for aux lights and such.
Also have you checked all fuses? One more thing, try flicking
your high/low beam switch back and forth a few times.
Shortleg[Dave]
9Ball
Re: Headlight reay
September 04, 2010, 11:32:20 AM »
could it just be a burned out filament for the hi beam? pretty unlikely both at the same time, but just thinking.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
