February 01, 2026, 03:52:25 AM *
Author Topic: Grease on Rear Wheel  (Read 1987 times)
Yellow99
Olney, MD
« on: September 06, 2010, 11:55:17 AM »
New to forum with 99 Standard. Just completed rear spline and pinion cup grease maintenance thanks to the Forum.Also replaced O-rings. Now after reassembly and a few hundred miles Grease is appearing on differential side of rear wheel in a spun on pattern.  Any ideas as to the cause?  I did remove plastic ring from Diff and reinstalled, is it possible this is not on correctly.  Bike makes no new noises
Thanks for any suggestions
Larry
cmc48
Yukon Oklahoma
« Reply #1 on: September 06, 2010, 12:18:53 PM »
I'm betting on o ring problem...did you replace the 3 o rings, possibily need to or maybe damaged one on reassembly
Yellow99
Olney, MD
« Reply #2 on: September 06, 2010, 01:47:50 PM »
I did replace all three O-rings and coated them with Grease on reinstall as mentioned in forum.  It seemed I got it right at the time.  Thanks for suggestion.
Larry
9Ball
« Reply #3 on: September 06, 2010, 02:15:52 PM »
probably just a little too much grease.
sounds like you did everything correctly.....
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
NITRO
Eau Claire, WI
« Reply #4 on: September 06, 2010, 03:33:58 PM »
I had the same problem on my Standard shortly after I bought it. I just assumed it was normal at the time. When we pulled the wheel off the next time, everything looked like new. I personally wouldn't worry about it and it's most likely extra grease like jrhorton said.
When in doubt, ride.
« Reply #5 on: September 06, 2010, 03:35:09 PM »
Yea mine did that to. It was still greased 15k later. No worries.
Yellow99
Olney, MD
« Reply #6 on: September 06, 2010, 04:57:23 PM »
Like what everyone is saying.  Was not looking forward to pulling rear again.  Will grease stop at some point getting on rear wheel and will there still be grease/ paste on splines for good lubrication?
Larry
« Reply #7 on: September 06, 2010, 08:35:30 PM »
If you packed the spline housing full, it'll push out when the heat builds up. Most folks over due the grease but it doesn't hurt. You just have a mess for a while.
