February 01, 2026, 03:52:26 AM *
Author Topic: Carb Cleaning  (Read 4263 times)
Tarkus
New Caney, TX
« on: September 08, 2010, 06:13:27 PM »
Hey all, newbie here.
Have a couple of tech questions.  Have a 98 standard in need of a thorough carb cleaning.  I'm looking at the carb rack on my workbench and I'm wondering what's the best way to remove the caps covering the pilot jets.  I'm thinking drill, but not sure what size drill bit or how much clearance before hitting the pilot screw.  Advice please.
Also, the bike came with the Cobra six into six pipes.  The carbs look like they still the factory jets.  Are the stock jets right match for these, or do these pipes call for rejetting?
Thanks in advance
Michael
Conformity is doing what everyone else is doing, regardless of what is right.
Morality is doing what is right regardless of what everyone else is doing.
John U.
Southern Delaware
« Reply #1 on: September 08, 2010, 06:22:36 PM »
Put the drill away. The only cap covering the jets is the float bowl. Remove that and the jets are at your disposal.
You may want to replace the stock float bowl screws with stainless hex screws as most of us do.
I run stock pipes so I'll leave the rejetting issue to others.
Pete
« Reply #2 on: September 08, 2010, 06:32:09 PM »
That d shaped cover is NOT a cover it is the screw for pilot adjustment. Requires a special tool.
Tarkus
New Caney, TX
« Reply #3 on: September 08, 2010, 06:32:33 PM »
Hey, John. Thanks for the quick response. The main jet and slow jet are accessible by removing the bowl.  But, the pilot jet needle is outside, and is covered by a cap.  I need to clean the pilot jet.  But first have to remove the needle.  Before I can do that the cap has to go.
Pete
« Reply #4 on: September 08, 2010, 06:38:43 PM »
Most of the time it is the Slow Jet that is clogged. Not the Pilot. See above post about Pilot.
John U.
Southern Delaware
« Reply #5 on: September 08, 2010, 06:41:03 PM »
That is true. Motion pro has a 1/4" D fiting to remove the pilot screw. Be careful not to lose the small pieces.
Many of us replace the slow jet (35) with a 38 to eliminate the "flat spot" and to somewhat reduce the tendency to clog. Sudco or Chaparral have the 38 slows.
Good luck
John U.
Southern Delaware
« Reply #6 on: September 08, 2010, 06:51:24 PM »
Tarkus,
Having just reread your recent post, I think I should add that there is no Pilot jet. When you remove the D screw you will have a needle, or metering rod an O-ring a small washer and a spring as I recall. A squirt of carb cleaner is all you can do with all that out. If the O-rings are in bad shape check out Redeye, he sells carb O-rings. Sometimes they hang up and need some assistance to come out.
You will need to set the pilots  to 2 1/2 turns out from lightly seated for OEM slows, 1 3/4 turns for 38s.
I had major problem cleaning the slow jets, wound up replacing them.
Tarkus
New Caney, TX
« Reply #7 on: September 08, 2010, 08:40:14 PM »
Tarkus,
Wow! Shocked  After taking another look, you're right.  It does have a D shape.  I'm glad I asked before I started drilling.  My only other experience doing this is with a V65 Magna.  It had caps over the pilot jets that needed to be removed.  I assumed that's what I was dealing with here.
Can't find the D fitting on Motion Pro you referred to.  Meanwhile, found a pilot tool online at Redeye.  They have two separate tools, one for "On Bike" and and another for "On Bench" adjustments.  As luck would have it they're out of the "bench" tool.
« Reply #8 on: September 09, 2010, 06:41:51 AM »
Michael, I can say with confidence that we all will be very interested in the outcome of your project.
So please be sure to let us all, here on the forum, be informed by you regarding how your Valkyrie runs when you get it back on the road.
9Ball
« Reply #9 on: September 09, 2010, 08:04:51 AM »
Make sure you clean the passage very well after the pilot screws are removed.  Of the 4 different carb sets I've cleaned, these were crudded up as well as the slow jets.  Two of the sets also had damaged pilot o-rings, so a replacement set of o-rings from redeye tech should be on hand.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
