February 01, 2026, 03:51:28 AM *
Author Topic: Muffler cover question  (Read 2031 times)
SANDMAN5
Mileage 65875
East TN
« on: September 10, 2010, 06:25:24 AM »
The muffler cover runs from just in front of the passenger peg to the
end of the exhaust tips. I just replaced the left side (clamps broke and
'disappeared') and thought I'd check the right side. The front clamp
is broke but the rear feels strong. Would JBWeld hold the front clamp
together or should I get some 'muffler repair' stuff. Will the JB hold
up under the temperature and vibration?
« Reply #1 on: September 10, 2010, 06:33:01 AM »
Would you like to purchase a set?  Email me if interested.
Baloo
Rimouski, Canada
« Reply #2 on: September 10, 2010, 06:43:52 AM »
No intention to cut Skinhead's deal, but the same happened to me. In my case, I was able to drill a hole and put an aluminum rivet (no rust). It was on the underside of the cover, so it does not show unless you're laying on your back when I go by..  uglystupid2 Might work for you...
Never ride any faster than your guardian angel can fly...
vanagon40
Greenwood, IN
« Reply #3 on: September 10, 2010, 06:55:56 AM »
. . . . Would JBWeld hold the front clamp
I've never had any luck with JB Weld on exhaust applications.  I do not believe it holds up well with the heat.
« Reply #4 on: September 10, 2010, 07:29:56 AM »
No sweat, If his can be repaired, that's great, I don't think JB weld will do the job though.  The pop rivet suguestion sounds like a good idea.  I was just trying to help a brother out if interested.  I plan to go with truck stacks and glass packs myself.
SANDMAN5
Mileage 65875
East TN
« Reply #5 on: September 10, 2010, 09:24:11 AM »
Hadn't even thought of the rivet thing!!!
Thanks anyway, Skinhead. cooldude
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #6 on: September 10, 2010, 09:35:08 AM »
I would be a little concerned about an aluminum rivet, won't take long for the edge of the cover to cut thru the aluminm. (I am assuming a hollow type pop rivet) A stainless rivet would last a lot longer.
Baloo
Rimouski, Canada
« Reply #7 on: September 10, 2010, 11:35:37 AM »
Actually, what I put on is a real rivet, not a pop rivet. The pop rivet has sort of a nail in it and I agree it would not last too long. What I used does not have the nail thing in and has a solid core. You install it in the hole and hammer the other flat.
