February 01, 2026, 07:05:13 AM *
Author Topic: final drive issue  (Read 4045 times)
dipstick
« on: September 11, 2010, 05:27:14 AM »
When riding the bike clunked a couple times in the drive train, so I pulled over, now it wont move at all. When you put it in gear and let out the clutch it just goes clickity click. I'm gonna tear it down later this weekend but am just wondering the best source for final drive parts. I have already spoken to someone much more familiar with this problem than I am and have got some good info already but I just wanted to pu it up here. The motor still runs fine and is definately a driveline problem, any additional ionfo would be great, thanks.
MP
North Dakota
« Reply #1 on: September 11, 2010, 05:30:45 AM »
Probably a u-joint.  Maybe splines/pinion cup on driveshaft.
You will need to get a used ujoint from pinwall or elsewhere, as new ones from Honda are backordered, with delivery expected in Feb. of 11, if I remember right.
MP
"Ridin' with Cycho"
« Reply #2 on: September 11, 2010, 05:39:44 AM »
Sounds a lot like the pinion cup... hopefully you won't need a currently hard-to-get u-joint.
Good luck...
Your dealer$ probably a fast place for new parts, Honda Direct Line
is a good on-line place...
Sodbuster
« Reply #3 on: September 11, 2010, 05:41:59 AM »
Out of curiosity .... how many miles on the bike ??
VRCC # 30938
« Reply #4 on: September 11, 2010, 06:31:58 AM »
more importantly...how many miles since the last drive shaft lube?
dipstick
« Reply #5 on: September 11, 2010, 06:34:57 AM »
45,000 on bike and right at 9,000 since last rear end service.
I have looked on pinwheel and cannot find the used parts link, what am I missing??
Kingbee
VRCC# 576
Northern Illinois
« Reply #6 on: September 11, 2010, 07:58:45 AM »
Here ya go
http://stores.ebay.com/PinWall-Cycle-Parts-Inc/_i.html?_nkw=valkyrie&_sid=12458664
1999 Interstate
2000 Interstate
2004 Rune
dipstick
« Reply #7 on: September 11, 2010, 09:31:08 AM »
Thanks Kingbee
Earl in Pensacola
« Reply #8 on: September 11, 2010, 09:43:00 AM »
Seems like in the not too distance past, someone on this site had confirmed that the U-jiont of a speciific year of the goldwind will fit.
dipstick
« Reply #9 on: September 11, 2010, 09:49:29 AM »
That would be nice if thats the problem cuz Pinwheel doesnt have any of the related parts that I could find.
« Reply #10 on: September 11, 2010, 01:38:31 PM »
All 1500 Wing U joints will interchange. Try a trike shop for one with the OEMs not available.
Sodbuster
« Reply #11 on: September 11, 2010, 02:43:54 PM »
If you search for BikeBandit part number 644090 you'll find that it fits ALL 1500cc Honda Goldwings AND Valkyries .... and in case your wondering they are on back order also.
VRCC # 30938
dipstick
« Reply #12 on: September 11, 2010, 05:36:00 PM »
Thanks, I kinda figured that would be the case.
« Reply #13 on: September 11, 2010, 05:52:52 PM »
Did you pull the drive-shaft out of the final drive and check it 9,000 miles ago also or just lube the splines ?
Tropic traveler
Silver Springs, Florida
« Reply #14 on: September 11, 2010, 06:46:00 PM »
+1......................
I had a PERFECT final drive hub, nicely lubed no sign of wear & a driveshaft/pinion cup all torn to heck about ready to fail.
Checking the d/s & pinion cup WILL be the new routine at every tire change!
Live & learn! Embarrassed Glad I caught it now rather than out on the road.  Shocked cooldude
'13 F6B red for Kim
« Reply #15 on: September 12, 2010, 09:49:48 AM »
Hard to tell exactly how bad the parts are since they are so crummy with junk.
It looks like the drive shaft is pretty bad however.
Mr.BubblesVRCCDS0008
« Reply #16 on: September 12, 2010, 02:56:25 PM »
I'ld bet you a dollar to donut that the pinon cup is stripped out. Easy fix less than a $100 to repair. Mine did the same thing one morning going to work.
dipstick
« Reply #17 on: September 12, 2010, 06:36:55 PM »
All I did 9,00 miles ago was to grease the splines, was not aware of the pinion cup issue. What exactly is the pinion cup of which you all speak? I cant find it in any parts listings. Is it the tranny end of the driveshaft? My mechanic is gonna pull it apart tommorow.
Thanks again for all the help.
« Reply #18 on: September 12, 2010, 06:47:14 PM »
The drive shaft jambs into the universal at the engine, and into the pinion cup at the wheel...
dipstick
« Reply #19 on: September 13, 2010, 02:38:52 AM »
Jay
« Reply #20 on: September 13, 2010, 09:39:38 AM »
I just pulled mine apart friday.  U-joint, propeller shaft and pinion joint are toast.  All parts are available except for the u-joint, backordered until Feb 2011.  WTF?
Does anyone know if the u-joint yoke can be machined so that the u-joint can be replaced?
Earl in Pensacola
« Reply #21 on: September 13, 2010, 07:19:10 PM »
Has anyone actually CONFIRMED that all 1500 Wing U-joints will enterchange with the OEM Valk U-joint??   If it's true, I just can't believe that all the wing U-joints are on back order too!!  I'll be changing my rear tire in a couple more months and have already ordered new dampers + inserts and brake pads.  After 9/25 (next billing cycle) I'll be ordering a new U-joint.  This will be my fourth U-joint.  However, the bike has 226K on her now.  I want to do everything at the same time.
dipstick
« Reply #22 on: September 14, 2010, 01:57:07 PM »
Well I still have not torn apart my rear end to see whats wrong but I was blessed in that a local trike shope had a complete 2001 Valk rear end he sold me REAL cheap. It is complete with a new metz tire swingarm, brake caliper, rotor and everything. So I hope Im good now and will have a spare from now on.
