SlowRoad
Hartselle AL
« on: September 14, 2010, 12:34:44 PM » |
On the way home from work yesterday my bike started popping on decel. last time this happened, it had blown one of the little plugs out of the redeye tech vacuum plugs. That was the first thing that I checked this time, but all the plugs look ok. It seems to be on the left side and the vacuum line to the petcock looks ok. Any other suggestions?
Thanks. Tim
Joe Hummer
Arnold, MO
« Reply #1 on: September 14, 2010, 12:40:47 PM » |
it could be...exhaust gasket...exhaust nut loose...intake o-ring...
Joe
1999 Valkyrie Interstate You pay for the whole bike, why not use it Jerry Motorman Palladino
SlowRoad
Hartselle AL
« Reply #2 on: September 14, 2010, 01:10:04 PM » |
I did visually check the exhaust nuts and they looked ok, but I will put a wrench on them when I get home. Intake o-rings should be ok as I just replaced them a year or so ago. Thanks.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #3 on: September 14, 2010, 01:52:33 PM » |
I don't mean to insult your intelligence, if you already know this: Be very careful twisting the header nuts. Doesn't take much to break a stud.
SlowRoad
Hartselle AL
« Reply #4 on: September 14, 2010, 02:08:26 PM » |
I do know they can break pretty easily, but I don't ever mind being reminded as I have been known to have a brain fart and do something stupid.
N8171S
« Reply #5 on: September 14, 2010, 02:16:09 PM » |
Bad Vacuum line.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #6 on: September 14, 2010, 02:24:43 PM » |
take some crc brand q-d electronic cleaner, and while the engine is running spray a little bit around the vaccum lines and vaccum plugs. if the motor revs up, then you will know that one is leaking (sucking) air.
sugerbear
« Reply #7 on: September 14, 2010, 03:15:57 PM » |
look at the redeye plugs you put on, is the center still in them? made my own and one popped out, had to look closely to see it. just a thought
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #8 on: September 14, 2010, 03:28:29 PM » |
Might also want to check the upper and lower intake boots. Mine loosened up twice in one year, second time I put the blue lock-tite on them. All is good  Everything mentioned above is good to check, I needed Intake runner o-rings, but that wasn't causing any popping. Vaccuum lines can't hurt to replace if you can't remember when you last did it. Check the torque on the header bolts, If it's off allot, get some new crush gaskets/washers and re-torque. Several of my friends have messed with this and we always change the vaccuum lines as a precaution if they can't remember when done last, almost always for us anyway, the upper boots are WAY loose. Seem to loosen with normal riding. Cheap fix too, couple turn of the screwdriver. Please post what you find for others.
SlowRoad
Hartselle AL
« Reply #9 on: September 14, 2010, 04:19:05 PM » |
That was the first thing I checked. All still there.
SlowRoad
Hartselle AL
« Reply #10 on: September 14, 2010, 05:07:24 PM » |
Might also want to check the upper and lower intake boots. Mine loosened up twice in one year, second time I put the blue lock-tite on them. All is good Tundra, looks like you hit the nail on the head. I tightened the lower intake boots and reseated the plug wires. For the sake of trying the simple stuff, I unplugged the plug wires one at a time to see if it made a difference. It did. I also sprayed starting fluid around the vacuum lines and no difference. I went for a short test ride after tightening the intake boots and all seems to be well. I will get a better test tomorrow on the ride to work. I will update either way. Thanks for all the suggestions. Tim
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #11 on: September 15, 2010, 03:16:23 AM » |
Glad that worked, easy fix  I would recommend checking the upper screw on the boot also, that's the one everyone forgets, as you can't see it. You can reach it with a 90 degree screwdriver. Or just take off the chrome choke slide cover (3 screws) If your lower was loose , I can assure the upper will loose also. Just takes a minute.
« Last Edit: September 15, 2010, 03:18:46 AM by Tundra »
