February 01, 2026, 05:38:55 AM *
Author Topic: Do I need a luggage rack?  (Read 2462 times)
Jackleg
The Real L.A. (Louisiana)
« on: September 16, 2010, 07:26:21 AM »
About to go on a short trip with the wife and needed more luggage space than the OEM leather bags would accommodate. I bought a Tourmaster large t-bag that straps to the sissy bar pad. I have the Corbin seat with the removable oval backrest that allows you to remove the OEM sissy bar mounting brackets. The Corbin backrest pad attaches to the seat with a square 5/8 inch aluminum rod. I do not have a luggage rack. The bag hangs a little lower than I would like when loaded but doesn't touch my brake light lens. I have never used a t-bag before and was wondering if it was a bad idea to use one without a luggage rack. I assume that the 5/8 square bar could easily hold the loaded weight (maybe 25 lbs). Obviously, a rack would eliminate any bag sag and it would be better to have one, but I thought I would ask for your opinions on running without the rack. Thanks in advance.
Colin
My old job
Orba, Spain
« Reply #1 on: September 16, 2010, 08:03:00 AM »
The bar should hold it BUT I wouldn't want to do it. The T bags are designed to support the weight on the rack and so the bottom of the bag may not be strong enough to do what you want.
Your choice but I wouldn't use it without a rack.
Colin
VRCC Espana
My Bumble Bee re-build
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #2 on: September 16, 2010, 08:09:44 AM »
When I got my bike, the previous owner had taken a 2500 mile trip, with a stock sissy bar, no luggage rack, with a t-bag. I could see a few scratches on the top of the tail light, where the bag had apparently rubbed a few times, but no other damage. I did put the bag on once, saw the sag, so went out and bought a stock luggage rack, since I have original seats.
As for the bottom of the bag - possibly something inserted to support it? The Tourmaster I have, seems plenty strong at the bottom, I wouldn't worry about doing it. Maybe yours is different?
R
« Last Edit: September 16, 2010, 08:11:32 AM by Walküre » Logged
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
Jackleg
« Reply #3 on: September 16, 2010, 12:30:29 PM »
One yay and one nay.......just my luck.
I forgot to mention in the original post that the Tourmaster bag is fairly rigid. The sides and bottom are reinforced with some sort of material that holds it shape. I was planning to put a short extension (maybe 4 inches) on the Corbin backrest post to get the bag up a few more inches in case it tries to settle while running down the road. The bag also has a neoprene cover on the bottom to keep from scratching the fender/tailtight. I do have a cruiser bar (not currently installed) that I could bolt up that would support one edge of the bag. I guess that is better than nothing at all.
Thanks again for the help.
« Reply #4 on: September 16, 2010, 01:47:34 PM »
If you had a pic it might be better. I'd use a rack myself. You could make something to mount to the sissy bar if you cant get a rack in time. Or borrow one from a member......
« Reply #5 on: September 16, 2010, 05:53:08 PM »
Mount the bag loaded with weight. Ride around town a bit and check for sag and fender rubbing. For future trips, I'd put a luggage rack on a purchase list.
vanagon40
Greenwood, IN
« Reply #6 on: September 16, 2010, 08:45:46 PM »
There is one for sale in the classifieds for $82 (shipped to your door).  I would buy the rack and not look back.  If nothing else, works to transport items too big to fit in the hard bags.
I would not be without my sissy bar rack, but I have a standard, not a tourer.
AND, I do not believe I understand your set-up, so I may be completely out in left field.
« Last Edit: September 16, 2010, 08:50:27 PM by vanagon40 » Logged
Kingbee
VRCC# 576
Northern Illinois
« Reply #7 on: September 17, 2010, 08:12:32 AM »
I mounted the bag so it rested on the pillion seat - problem solved!
1999 Interstate
2000 Interstate
2004 Rune
BamaDrifter64
Athens, Alabama
« Reply #8 on: September 17, 2010, 08:22:42 AM »
I don't think his wife would appreciate holding on to or sitting on top of the T-bag.... 2funny
Dave
Kilroy
Clearwater, Florida / Overland Park, KS
« Reply #9 on: September 17, 2010, 09:21:13 AM »
Put on a rack and you will always have the capability to carry small items with or without the bag.  I think it is a good inverstment.
"I was here, but now I'm gone"
john
tyler texas
« Reply #10 on: September 17, 2010, 05:58:26 PM »
 " the differance between what goes and what stays behind "     coolsmiley
where did i see that ?      coolsmiley
vrcc # 19002
Jackleg
« Reply #11 on: September 20, 2010, 07:25:01 AM »
Thanks for all the input guys. I normally ride solo (my wife coming along is rare) and like the look of a clean rear end (....sound of the door opening for comments) so I was trying to stay away from the rack which would require me to remove fender rails everytime I install/remove. I worked on a backrest extension this weekend and I think it will work. I was tapping the last bolt hole when the bit broke off. I will post pics once I get the set up complete.
