February 01, 2026, 05:37:34 AM *
Author Topic: fog lites?  (Read 2201 times)
henry 008
BRP
willard, oh
« on: September 17, 2010, 03:23:10 PM »
i'd like to ad some lites to  my 00 I/S. is there a connection already in the faring or pods for the honda fog lites?  or do ineed to run wires to my battery/fuse box?
Safe Winds... Brother
Big Mike
I can not remember my last bad day
Taylor MI
« Reply #1 on: September 17, 2010, 04:29:49 PM »
valkyriebling has fog light kits for the I/S. There is already wiring available on the bike if it has not been used for anything else.
Big Mike
VRCC 23871
VRCCDS 0200
With GOD and a good attitude, there is no circumstance that I can not overcome.
henry 008
BRP
willard, oh
« Reply #2 on: September 19, 2010, 07:02:53 PM »
where would the available wiring be?
Big Mike
Taylor MI
« Reply #3 on: September 19, 2010, 07:31:23 PM »
Wires are behind the right side cover. There are 2 wires with female ends protected by a small black cover around both of them. Not the large boot that covers many wires.
Big Mike
VRCC 23871
VRCCDS 0200
henry 008
BRP
willard, oh
« Reply #4 on: September 20, 2010, 07:22:36 AM »
are these switched wires, or do they come on with the headlights?  i'm assuming you can still buy the male ends so i can jus plug and play. thanks mike
Kaiser
Gainesville, FL
« Reply #5 on: September 20, 2010, 09:30:44 AM »
check the classifieds. (not my post and not affiliated, just giving you a head's up that there are a pair on there)
henry 008
BRP
willard, oh
« Reply #6 on: September 20, 2010, 09:49:15 AM »
i have the lights already, i jus wanna hook em up. thx
Big Mike
Taylor MI
« Reply #7 on: September 20, 2010, 03:20:49 PM »
They are tied into the ignition system so they will turn on and off with the starter switch and ignition key.
Big Mike
VRCC 23871
VRCCDS 0200
henry 008
BRP
willard, oh
« Reply #8 on: September 21, 2010, 07:25:21 AM »
thx, will check it out this weekend at the tech session at  ricks!
« Reply #9 on: September 21, 2010, 07:59:13 AM »
Depending on the current draw you may need to run the lights through a relay and get the load off of the starter switch.
John U.
Southern Delaware
« Reply #10 on: September 21, 2010, 06:21:33 PM »
You will need a relay. The wires under the side cover can't handle the load of auxilliary lights. Use the + wire to trigger the relay and run a separate hot wire from the battery.
Or, you can install a fused power buss to handle future additions:
 http://www.electricalconnection.com/power-distribution/pplate.htm
