February 01, 2026, 05:38:49 AM *
Author Topic: Spark Plug Corrosion / Residue?  (Read 3882 times)
BuzzKill
Lake Dallas, Tx
« on: September 18, 2010, 01:36:53 PM »
I replaced these plugs about 1 year/10k miles ago.  The bottom plug in the picture is from the cylinder 6 (rear left), and the top is from 5 (opposite).  All the plugs on the left have about the same look as #6 (thick white residue and what looks like rust on outside) and all the ones on the right look like #5 (mostly clean with slight white residue on outside).
My questions are,
1.  Is it effecting preformance, such as mileage?
2.  What is causing it?
3.  Do I need to replace em?
4.  How can I keep it from happening again.
« Reply #1 on: September 18, 2010, 02:02:48 PM »
Looks like water is pooling in the spark plug hole of the head.  I believe there is a drain hole in each plug well, I would check and make sure they are open and draining.  If the plug well is filling with water, you may short out the plug when water is present and have a miss/ dead cylinder until the water evaporates.
Michvalk
Remus, Mi
« Reply #2 on: September 18, 2010, 02:19:32 PM »
+1. And,yes, I would replace the plugs cooldude
« Reply #3 on: September 18, 2010, 02:47:07 PM »
+1 what skinhead said.  wire brush them and use anti-sieze on threads.
Thunderbolt
Worthington Springs FL.
« Reply #4 on: September 18, 2010, 06:45:49 PM »
in the spark plug well.
« Reply #5 on: September 18, 2010, 10:43:15 PM »
You guys have it handled  cooldude except for the color on the center electrode looks really good Grin
