February 01, 2026, 05:38:55 AM *
Author Topic: fuel lines/fittings  (Read 1751 times)
v-man1
« on: September 20, 2010, 06:59:16 PM »
getting ready to change oem petcock for pingle,install dan marc elect. fuel shut-off valve and pingle fuel filter,in that order.Should I go with plastic or brass tee fitting at split-off to carbs?Also doing desmog at same time.Any other thoughts anyone has on this set-up would be appreciated.Thanks
« Reply #1 on: September 20, 2010, 08:29:23 PM »
You might consider putting the filter between the Pingle petcock and the electric shut-off. As for filters, I just used an automotive unit, the filter I used is like the one Redeye has in their kits. I installed the Dan Marc right after it with a short piece of hose separating them.
http://redeye.ecrater.com/p/5138850/frankenfilter-fuel-line-and-filter-for-valkyrie
Disco
Republic of Texas
« Reply #2 on: September 20, 2010, 09:18:11 PM »
When I replaced my fuel lines, I reused the oem tee.  3/8" fuel line + oem clamps work great at the tee and carb banks and petcock nipple.
When we put a Pingle in Six Guns IS, we needed a screw type clamp to get the 3/8" sufficiently tight at the Pingle.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
