January 28, 2026, 09:53:55 AM *
Author Topic: Carb Question  (Read 3618 times)
thewoodman
Bradenton, FL
« on: March 28, 2009, 05:39:30 PM »
After doing yeard work ALL day today, I was tinkering around with my '97 Tourer and found 2 rubber hoses had come unstuck from the bottom of the float bowls on carbs 3 and 5. Brain dead and figuring that these were vacuum related somehow, I went about reconnecting them. The #3 was especially enjoyable because of the idle adjuster. Now I find out that these tubes are float bowl drain tubes. Is there anything else I should be aware of before buttoning everything back up. Re-threading the idle adjuster will have to wait until tomorrow morning.
thanks in advance.
woodman
TheWoodMan
