February 01, 2026, 05:38:55 AM *
Author Topic: New Clutch fix --- first time I ever saw this?  (Read 2157 times)
Pete
« on: September 21, 2010, 05:25:06 PM »
Bike was having symptoms like:
Hard time finding neutral
Clutch lever got hard just before full  dis-engagement.
Solution:
The brass bush was missing in the lever, the master cylinder rod was against the rear of the hole in the lever. It had been this way for awhile, it had wore a small groove in the lever.
So someone removed 3 parts, lost 1 and reassembled with 2.  (NOT ME)
Some folks should not have access to wrenches or at least should have there wrench privileges revoked.
So if you are having clutch/lever issues  --- check the obvious.
« Reply #1 on: September 21, 2010, 05:52:36 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,20066.msg181081.html#msg181081
You didn't look this is only one of the more recent posts on the issue Valkpilot knows his stuff too and finally gave in and replaced the clutch. Grin There isn't to much that hasn't already been covered, never hurts to restate it but if most would just search their topic in either the new or old tech talk it all would be there.
« Last Edit: September 21, 2010, 05:57:02 PM by Robert » Logged
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: September 21, 2010, 05:56:09 PM »
Solution:
You're absoultely right that one should check the easy and obvious first.
I'm glad that's all it took to fix yours.   cooldude
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Pete
« Reply #3 on: September 21, 2010, 06:45:21 PM »
Yes Robert I had read that post, and was aware of his fixes, this was not related to that.
FYI a search of clutch bush missing  --- found NO results.
Just a post of something different that I had not seen before.
« Last Edit: September 21, 2010, 07:17:17 PM by Pete » Logged
FryeVRCCDS0067
Brazil, IN
« Reply #4 on: September 21, 2010, 07:38:21 PM »
Solution:
Missing bushing was one of the many problems we found when my son bought his valk. The levers had been replaced and the bushing was left out then I imagine.
Pete
« Reply #5 on: September 22, 2010, 12:18:53 PM »
Solution:
I suspect that the same happened here --- since the bike had chrome levers  --- might have even been the same person (ha ha ha) cooldude
