March 20, 2026, 12:48:51 AM *
Author Topic: mechanic  (Read 1477 times)
slider
mulberry arkansas
« on: September 22, 2010, 06:39:44 AM »
anyone out there know of a good valk mechanic around Fort Smith Arkansas??Have a dealer 60 north but just am not convinced about their service shop..any help would be welcome ..thanks  slider
« Last Edit: September 22, 2010, 06:42:10 AM by slider » Logged
a proud navy veteran
Jack
Benton, Arkansas
« Reply #1 on: September 22, 2010, 08:22:27 AM »
I doubt any good Valk mechanics exist at the dealers.  A Valk rarely needs work and they haven't sold any new Valks in 7 yrs.  You would be better off finding a fellow Valk owner in the area that likes to work on bikes.
Joe Hummer
Arnold, MO
« Reply #2 on: September 22, 2010, 08:27:46 AM »
What do you need to have done to it?  It might be something that can be easily explained and you do the work yourself.
Joe
1999 Valkyrie Interstate
slider
mulberry arkansas
« Reply #3 on: September 22, 2010, 10:30:58 AM »
not having a problem with the Bee (no surprise)planning on having the rear end service done and have my doubts about being able to securley get it raised up high enough to preform the service I want to do,want to do the drive shaft/u-joint inspection and drive spline service,had new tires put on at dealer and asked them to ck the drive splines and make sure they were lubed and ok--But just dont really trust them to do it..so like most of the riders on here decided might be best to do it myself and know its done right,,the information on here is great for me since I am a newbie valk owner and like you all I love the dragon!!I have been riding since 13 yrs old and rode wards riverside 125-Kz1300 kawasakis,Bmws ,several harleys,BUt in my opinion the valk is the best of them all..I am proud to be amember of this elite group of dragon riders.
« Last Edit: September 22, 2010, 10:33:34 AM by slider » Logged
Joe Hummer
Arnold, MO
« Reply #4 on: September 22, 2010, 10:51:51 AM »
Email sent with instructions...let me know if you have questions.
Joe
Paul-M
Northern Vermont
« Reply #5 on: September 22, 2010, 12:45:54 PM »
Hey Joe,
I've done my rear splines (with moly paste and replace the washer and 3 o-rings) but intend to remove the and service the driveshaft and take care of the u-joint splines this winter. I intend to convert my valk over to a CT at the same time and want to make sure I'm doing everything right.   Undecided   Would you mind sending a copy of those instructions to me as well?
Incidentally, how often should the o-rings and washer be replaced? Should I replace them again while I have things apart even though I did it in July? I have only ridden a few hundred miles since I put the 'ol girl back together again.
Thanks in advance,
Paul
Paul Martin
2000 Valkyrie Tourer
2001 Valkyrie Standard (sadly retired)
Joe Hummer
Arnold, MO
« Reply #6 on: September 22, 2010, 07:25:40 PM »
Hey Joe,
Thanks in advance,
Paul
Email sent.
Most will tell you that it is cheap insurance to replace the o-rings every time you take the wheel off.  For most people...that is once a year or two.  For others...it is definitely once a year. (depending on what tire you are running and your riding style.)   It is not the assembly, disassembly that is the problem...it is the wear from rolling over the o-rings.  Since you are going to a car tire...i would say replace them every time you take it apart to re-lube the splines....or once a year...whichever comes first.
Joe
big turkey
« Reply #7 on: September 23, 2010, 03:53:44 AM »
Buy the Jig that fits the holes on the motor and will support the bike correctly.
I made my own.
This will get it high enough.
buy your parts before you do this.
Smaller bearing on the outboard side, just replace it, it is a problem.
Lube it with Ketchup, yes Ketchup, because any grease I mention will be wrong to somebody.
Moly is the slickest stuff on the planet, mined from porforry shorings, it is good to have 60%,
Guard Dog is higher in Moly, at 75%, Honda sells the 60% stuff and should be adequate.
Main thing is get a grease that will not migrate at 400 degrees and there are lot of those.
Make sure you leave the four bolts on the differential loose, one turn out from snug.
Tighten these last, it is the magic touch of this operation.
Enjoy your bike then.
slider
mulberry arkansas
« Reply #8 on: October 18, 2010, 02:18:13 PM »
thanks joe your  email was a great help ob went very smooth    I just took my time and followed instructions  thank you for your help
Joe Hummer
Arnold, MO
« Reply #9 on: October 18, 2010, 02:59:02 PM »
Excellent Slider!!  Glad the instructions helped.
Joe
