fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: September 22, 2010, 12:43:40 PM » |
Last wknd, I rode a couple hundred miles out and rode around for, probably, 150 miles before starting back. About 75 miles into the return trip I started running into rain. Shortly thereafter the Valk began losing power and stalled like she'd run out of gas. After a couple of times I began cracking the gas cap periodically and got home without further engine stalling.
I just now checked the vent hose and it was not kinked or blocked.
Any insights?
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: September 22, 2010, 01:16:42 PM » |
Mike,
There have been a few reports of the vent tube hanging beneth the bike (near the Dragon Drool tube that comes out under the swing arm), picking up water, in heavy rain, and causing the problem you describe...
Some have shortened this tube to correct the issue.
Black Dog
Just when the highway straightened out for a mile And I was thinkin' I'd just cruise for a while A fork in the road brought a new episode Don't you know... Conform, go crazy, or ride a motorcycle...
fiddle mike
Corpus Christi, TX
« Reply #2 on: September 22, 2010, 01:51:15 PM » |
Mike,
Black Dog
Thanks, BD. I'll give that a shot. Rain is still cramping my style, here.
Pete
« Reply #3 on: September 22, 2010, 02:14:21 PM » |
Check the T in the vent line to be sure that it is clear and not pressing up against something.. The T is there to break the suction, so the low end does not gather and hold water.
fiddle mike
Corpus Christi, TX
« Reply #4 on: September 22, 2010, 02:17:27 PM » |
10-4
wizard -vrccds#125
« Reply #5 on: September 22, 2010, 02:18:35 PM » |
Does your vent tube have the "T" in line for venting ? That prevents it from sucking water !
fiddle mike
Corpus Christi, TX
« Reply #6 on: September 22, 2010, 02:25:10 PM » |
No, it doesn't. I must have scrapped it when I discarded the crankcase vent reservoir, not knowing what it was. The last time I got caught in any real rain it was so heavy I couldn't see and pulled off the road, so I've never missed the T.
« Reply #7 on: September 22, 2010, 03:35:42 PM » |
.... so I've never missed the T
You have now.
petevenne
« Reply #8 on: September 22, 2010, 03:41:48 PM » |
Dumb question, but what if if you did not even connect the hose? Is it there to prevent smokers from blowing up with a nasty ole butt in their mouth @ a stop light...Should be ok for non smokers?? It's only a vent hose....
Thanks, Pete
fiddle mike
Corpus Christi, TX
« Reply #9 on: September 22, 2010, 03:48:21 PM » |
Thanks, Pete
I took the tank off before I posted the question. The hose is still on the vent and is long enough to reach the keeper on the side stand bracket. I don't want godless smokers to explode my baby.
fiddle mike
Corpus Christi, TX
« Reply #10 on: September 22, 2010, 03:49:32 PM » |
You have now.
 Yeah, you lives and you learns.
« Reply #11 on: September 22, 2010, 04:14:11 PM » |
Do ya even need the vent line. seems alot have trouble with them getting kinked anyway. Only thing i would see is 'if' gas expanded it would run all over. I have only seen 1 valk leak in my travels. Mine never has. Just thinking out loud.
fiddle mike
Corpus Christi, TX
« Reply #12 on: September 22, 2010, 04:20:51 PM » |
Do ya even need the vent line. seems alot have trouble with them getting kinked anyway. Only thing i would see is 'if' gas expanded it would run all over. I have only seen 1 valk leak in my travels. Mine never has. Just thinking out loud.  Mine has never leaked but I've heard of it happening when the tank is overfilled. I've always managed to keep the tube from getting kinked, though I've seen it happen on other Valks.
« Last Edit: September 22, 2010, 04:23:17 PM by fiddle mike »
Pete
« Reply #13 on: September 22, 2010, 04:23:08 PM » |
Just go about half way down the hose and put a T or drill a small hole on 1 side.
fiddle mike
Corpus Christi, TX
« Reply #14 on: September 22, 2010, 04:25:01 PM » |
I found the original vent tube with the T in it stashed in my important stuff collection.
Daniel Meyer
The State of confusion.
« Reply #15 on: September 22, 2010, 07:19:03 PM » |
Thanks, Pete
It's also an overflow. It will drench your alternator if it overflows any while on the side stand.
CUAgain, Daniel Meyer
wizard -vrccds#125
« Reply #16 on: September 22, 2010, 07:21:18 PM » |
Fill with cold fuel then let it sit in the sun awile and see what happens !
donaldcc
« Reply #17 on: September 22, 2010, 07:42:02 PM » |
So if I fill my tank on the kick stand and then put in that last 0.2 gallons by standing up bike vertical and slowly filling up to the bottom of the "filler hole" or whatever that is called . . . Is some of that top off going out the vent??
Never see any on the floor and I frequently top off just before heading home and I fill close to home.
Don
roboto65
« Reply #18 on: September 23, 2010, 02:21:34 AM » |
I have not had a hose on mine for year or so no problems YET
Allen Rugg VRCC #30806 1999 Illusion Blue Valkyrie Interstate 1978 Kawasaki KZ 650 project
VMODON
« Reply #19 on: September 24, 2010, 04:52:24 PM » |
Petcock, Petcock, Petcock. How old is it. Do yourself a favor and put pingle in , before you go crazy trying to troubleshoot...
« Reply #20 on: September 25, 2010, 06:45:59 AM » |
