February 01, 2026, 05:38:55 AM
Is there a Rev Limiter on a 97 Valk?
Topic: Is there a Rev Limiter on a 97 Valk? (Read 2334 times)
Momz
ABATE, AMA, & MRF rep.
September 22, 2010, 06:30:57 PM »
A friend loaned another friend his 97 standard (with a maladjusted throttle lock), and the throttle stuck wide open for 15-20 seconds on start up. They believe the motor is damaged, but it seemed to run fine on the way home.
I know my 2K I/S is rev limited at about 7200 RPM, but they claim that the 97s did not have this feature.
Can anyone settle this dilema so that everyone concerned can calm down?
ALWAYS QUESTION AUTHORITY!
shortleg
maryland
Re: Is there a Rev Limiter on a 97 Valk?
September 22, 2010, 06:38:53 PM »
I thnk you will find that all our Valk have the same
limiter installed on them.
After all,they say they know us.
Shortleg[Dave]
September 22, 2010, 06:45:28 PM »
I hae '97. I have hit the rev limiter a couple times. Im positive mine is so equipped
Brovietnam
September 23, 2010, 05:33:31 AM »
I would say that it does also. Mine won't run over 125 mph indicated.
I have heard other people have taken the limiter off and have been able to go markedly faster.
MP
North Dakota
September 23, 2010, 05:49:22 AM »
I have a 97, and it has a limiter. It is in the computer, I do not know how anyone could "take it off"?
If you put a dyna 3000 on it, then you can up the revs.
There is no way a stuck throttle would wreck the motor, unless left running like that for a long time.
MP
"Ridin' with Cycho"
September 23, 2010, 06:21:24 AM »
Quote from: Brovietnam on September 23, 2010, 05:33:31 AM
The rev limiter does dot limit top end speed. It kicks in around 7K rpms........youre not anywhere near 7k at 125mph
Momz
Reply #6 on:
September 23, 2010, 05:32:29 PM »
Quote from: MP on September 23, 2010, 05:49:22 AM
MP
