January 31, 2026, 01:39:53 PM *
Author Topic: Battery Life  (Read 5686 times)
KW
West Michigan
« on: March 28, 2009, 08:18:11 PM »
I'm still using my ORIGINAL battery on my Valk. It's a 99 Standard, so it's been about 10 years now. What's everyone's average battery life on thier Valk? My last bike was a Yamaha and she ate up batteries about every other year. So, 9 + years seems pretty good to me  laugh I just started her last week and rode about 200 miles. She fired right up. I live in the cold, but ALWAYs take my battery inside every fall and I have NEVER used a battery tender. (I'm not trying to start an argument about using tenders!!) Thanks Guys!
PS - I haven't posted anything is a number of years. In fact, I had to re-sign up. I like the changes
MP
North Dakota
« Reply #1 on: March 29, 2009, 04:18:54 AM »
Taking inside is probably what kept it alive so long. It really helps when it gt sreal cold.
"Ridin' with Cycho"
blkvlk777
« Reply #2 on: March 29, 2009, 04:29:24 AM »
Have a 98 standard / 99 tourer - both with the original batteries.  I did purchase 2 new batteries this year for the bikes - went with the same brand.  I use a harbor freight battery tender.  I read that lots of times the battery gives no warning signs and just will die (actually happened to a buddy of mine with his Valk).  Both batteries still turn the bikes over like they are brand new however I consider it preventative maintenance and at 10 / 11 years it owes me nothing.  I myself am still amazed/impressed at how long the batteries have lasted.
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #3 on: March 29, 2009, 06:08:46 AM »
Quite a few of us have had good luck with the OEM battery.  I got 6 years on mine, and only changed on the advice of those on the Tech Board that I trust to have taught me a lot of good stuff to keep my Valk runnin' fine  cooldude
The main arguement against keeping a battery over 5 years, is that it really stresses your charging system, keeping an older battery up to snuff...  Don't know 'bout you, but I find it much easier, and less expensive, to change a battery every 5 years or so, compaired to swapping out an alternator  Shocked
Another reason, is things usually give ya their final effort, and go belly up, when yer in a place that is not very condusive to gettin' it fixed.  Get a new battery every 4 or 5 years or so, save yer charging system, and give yer worrier a break.  Use the old battery as a 'bench tool', and ride it like ya stole it!
Black Dog
Don't you know...
« Reply #4 on: March 29, 2009, 06:32:14 AM »
My 98 battery lasted till 03. Always on the bike and no tender. Thinking about changing mine again. When mine went, it went fast. No warning what so ever.  Evil
Gary
Northern New Mexico
« Reply #5 on: March 29, 2009, 07:13:32 AM »
My first lasted about 4.5 years, my replacement, another Yuasa, has been in there since 8.5 years. The first died on the spot, as others have mentioned, but in my garage thank goodness.
Guess this is a great reminder to get one ordered.
Never used a tender, always just went in religiously once a week during the snow seasons of NW Illinois, western OK, Southern Colorado and NW New Mexico and fired her up. So far so good.
Wildman
« Reply #6 on: March 29, 2009, 07:49:55 AM »
I have a 2000 Std. with 64 K the originall battery is still going strong. I leave it in all winter In Vermont with a battery tender and start it once a month and run untill the colling fan has cycled on and off a few times ( taht takes a while when its 10 degrees out.
My question is; When the batterie dies suddenly and completely can the bike still be push started?
If si I migth wait for the batter to give up the ghost.
If not it's already past time to replace it.
Thanks for any responces.
rmrc51
Palmyra, Virginia
« Reply #7 on: March 29, 2009, 08:23:15 AM »
Good topic.   cooldude
And related to it, are there any opinions positive or negative regarding the use of a Battery Tender? I've always used one on my old cars and now plan to do the same with the Valk.
I'd also like to hear if these Valk's can be push started.
VRCC # 30041
DeathWishBikerDude
« Reply #8 on: March 29, 2009, 08:40:26 AM »
The original battery lasted me 7 years,a new world's record.
The power max I've replaced it with has lasted 4 so far.
I always bring my batteries indoors for winter,but never had many batteries last 2 seasons before the Valk.
 Shocked
Wildman
« Reply #9 on: March 29, 2009, 11:05:15 AM »
I have push started my Valk several times in 2005 due to a wiring issue that dragged the battery charge down, and eventually killed the alternator. I Fixed the wiring, replaced the alternator, and I'm still running the same battery.
What I don't know is, does a suddenly dead old battery create a short in the system ? Or maybe is the battery finally shorting out and causing sudden death?
I am assuming that this type of problem would prevent a jump start
Black Dog
VRCC # 7111
« Reply #10 on: March 29, 2009, 01:28:42 PM »
On the subject of 'Push Starting', the answer is yes...  Really works quite well.
To underscore the point I made above, running an older battery (one 5 plus years old), you are taking a big chance of over working the alternator.  As a battery ages, it does not hold a full charge as well as a newer battery does.  This means your alternator works harder, and as many here on the board can attest, replacing an alternator is big work, and big bucks.  $75 every 5 years is pretty cheap insurance.
When the Valk battery starts to go, it still cranks like crazy, but our beasts need all the juice the battery can muster.  You can crank away, but the voltage may be just a bit below the required to fire the beast up, and we're choking it, givin' it a bit of throttle, and gettin' frustrated.  I've seen guys crank a Valk, until the battery is dead, then get a 'jump' from a cage, and spring to life in an instant.
On battery 'Tenders'...  I've used a unit called 'BatteryMinderPlus' for years, on the Valk, our three 4Wheelers, and my boat batteries.  The unit not only keeps the battery charged, but 'desulfates' the battery, once it reaches optimal charge.  Cool thing about it, is that one unit can charge up to 4 batteries at one time.  I made a special three port harness, and keep three 4Wheelers hooked up when not in use.  Over the long Wisconsin winter, I use a second unit, and alternate every other week, between the Valk, and my boat battery.
$50 at Northern Tool ( http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200332201_200332201 )
I'm no expert, but when it comes to the Valk, I'll be a bit more cautious...  Half way across Kansas, on the way to InZane, is the wrong time to find out ya need a new battery.  Some folks seem to get a special kick, outta saying they have an OEM battery in a '99 Valk.  I'd rather part with 50 bucks, after 5 years than fork out $250 plus labor and down time when the alternator pukes.
Just my .02, and wort what ya paid for it.
Ride safe, ride hard  Grin
Black Dog
Don't you know...
KW
West Michigan
« Reply #11 on: March 29, 2009, 02:15:51 PM »
I wasn't "getting a kick" out of saying I had my OEM battery in my 99 Black Dog.  I was just curious about how long batteries lasted in Valks. I honestly didn't know. . .  I don't get your answer. My question was a fair, honest topic and you take a shot at me? It's my first post in 3 years. You don't know me.
Oh well. I remember now why I stopped coming here. Nothing much has changed, other than the graphics, only I have to say, the Tech board didn't have it as much. . .
Black Dog
VRCC # 7111
« Reply #12 on: March 29, 2009, 02:28:01 PM »
KW, I didn't mean to diss you in any way...  Ask anyone here, I'm not one to pick fights.  I'd rather just kick tires and talk bikes  Grin
Sorry you took my post the wrong way.  When I made the comment about folks bragging about how long their OEM batteries have lasted, I was only pointing out the possible ramifications...  Never meant that to be pointed at you.  I'm sorry if I offended you.
Don't let the fact that my post struck you as an attack keep you away.  We need all the members we can get, and I never want to scare one away.
Meet me at InZane, and a beverage of your choice is on me  cooldude
Black Dog
Don't you know...
« Reply #13 on: March 29, 2009, 02:58:44 PM »
I saw no disrespect in the post. He's a good guy. He was just pointing out potential problems that could go wrong with a older battery. Don't take it to heart. I'm on my second battery and will put in another here shortly. I had my alt looked over last month by a alt guy and mine was good. He just repacked the bearings. 47,000 miles on my 98 CT. As stated in my previous post. My battery failed without warning while I was out shopping. That was 03 with less then 20,000 on her. No way I can push start this hogg by myself! Make sure the new battery is fully charged before putting it in the bike.  Evil
John U.
Southern Delaware
« Reply #14 on: March 29, 2009, 03:05:08 PM »
Plus one on the Battery Tender Plus. I'm using a single unit to swap between three bikes, it even rejuvenated a battery on a Yamaha that eats batteries. Sulphation kills a lot of batteries, especially if they are allowed to sit in a discharged condition.
Regarding previous posts, it's often impossible to tell who is responding to what on any board. Around here if you stay off the car tire topic you wiil avoid a lot of stress.  Lips Sealed
fordmano
San Jose, CA.
« Reply #15 on: April 01, 2009, 01:13:15 AM »
I put my first new battery in my 99 I/S  just a couple of months ago if I remember correctly.
Paid toooooo much for it but I love GELL batteries so I wanted to try one out on the bike.
I will be happy if the new one lasts for anything more than 5-6 years.
« Last Edit: April 16, 2009, 01:34:35 AM by fordmano » Logged
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Wildman
« Reply #16 on: April 01, 2009, 03:35:32 AM »
The Valkyrie is very smooth running. No Vibration.
This may be one of the reasons that the batteries last so loong.
I have friends with Honda V-twins that are repacing their batteries every year or two.
Anthony
Belgium
« Reply #17 on: April 01, 2009, 03:36:09 AM »
1998 Standard,
i replaced the OEM in 2008, after reading some good advice on this board about how long they normally last...
it had been on a tender only the last winter during that period.
the bike did have an easier start with the new one :
it did have more energy to turn over the starter engine AND ignite the sparks.
Anthony
N0tac0p
« Reply #18 on: April 01, 2009, 04:48:01 AM »
ANY LINKS TO A GOOD CHEAP BATTERY FROM A REPUTABLE SOURCE
Jack
Benton, Arkansas
« Reply #19 on: April 01, 2009, 04:50:40 AM »
Mine lasted 6 years and died the first winter I lived in Arkansas.  I'm really not happy with Arkansas weather after living on the Gulf for several years.  I'm putting many less miles on my Valk here.
John U.
Southern Delaware
« Reply #20 on: April 01, 2009, 06:55:23 AM »
I'm not sure you can get good and cheap at the same time. Considering that many of us have gone 10 years on the OEM Yuasa, I think on a bucks per year basis, that makes the Yuasa a good choice. http://www.batterystuff.com/batteries/motorcycle/YTX14-BS.html
John U.
Southern Delaware
« Reply #21 on: April 01, 2009, 07:02:34 AM »
By the way, if you have an IS or a lot of added accessories you may want to consider this one
http://www.batterystuff.com/batteries/motorcycle/YTX14H-BS.html
Rocketman
Seabrook, Texas
« Reply #22 on: April 03, 2009, 10:02:24 PM »
The deader the battery, the harder the push.  Can be done, though.  Easily, if the batt. is just barely gone.  She'll leave you panting next to a cold engine if she's really dead, though.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #23 on: April 04, 2009, 04:10:24 AM »
Typicaly 6-8 years on my batteries. Never use a battery tender, what's that winter thing you all keep speaking of? 2funny
« Last Edit: April 04, 2009, 04:12:50 AM by Tundra » Logged
Slyk Willy
Michigan
« Reply #24 on: April 06, 2009, 05:46:34 AM »
It seems like folks are anti-Battery Tender. I've used this on my bikes and wife's forever with no adverse effects, What's the concern about them?
Slyk Willy VRCC # 16194
rmrc51
Palmyra, Virginia
« Reply #25 on: April 06, 2009, 05:57:40 AM »
I'm also curious about hearing any negative experiences. I've been using the Battery Tenders for years with no problems at all on my old car, garden tractor and motorcycle.
VRCC # 30041
vanagon40
Greenwood, IN
« Reply #26 on: April 06, 2009, 06:06:25 AM »
I just reread the entire thread twice did not see a single negative comment about a battery tender.  Did I miss something?
Slyk Willy
Michigan
« Reply #27 on: April 06, 2009, 06:16:02 AM »
I read
Typicaly 6-8 years on my batteries. Never use a battery tender, what's that winter thing you all keep speaking of? }
as a directive NOT to used the battery Tender. On re-reading i believe the point is that he has never used it on his battery. Sorry.
Airetime
Anacortes, WA
« Reply #28 on: April 06, 2009, 06:45:30 AM »
I have had mine for 8 years BUT I use a Battery Tender every winter for about 3-4 months (gotta Love them) I get about 5-6  years on th eaverage, so this is an exception. If it lasts this season, I am going to replace it, not going to gamble with Lady Luck  Shocked
vanagon40
Greenwood, IN
« Reply #29 on: April 06, 2009, 08:03:31 AM »
No need to apologize, I see your point.  I have not used a battery tender, but I try to keep the temperature in my garage above freezing.  Maybe that helps.
Grandude
« Reply #30 on: April 06, 2009, 12:20:58 PM »
I just bought one from the local Batteries Plus for $75. I can't remark on how good it is, just the price and source.
nors
« Reply #31 on: June 27, 2010, 08:35:47 AM »
Is there a stronger battery for Interstate models?
My battery charge only lasts 2 days now, so I'm going to install a EverStart from Wally World as a temporary fix.   The previous owner did very little maintenance on the 00' never even changed the coolant  Shocked so I'm sure this Yuasa is the original.  Shame, shame, such a beautiful muscle bike not to maintain well and frequently.
« Reply #32 on: June 27, 2010, 09:52:28 AM »
I solved the problem of guessing how good my battery is (I think so anyway)  I installed a Volt meter and I have a switch so I can turn on the volt meter while the bike is off to see what the battery is holding, then watch it climb as the bike is running to see what the altenator is puting out.  Last year I noticed the battery was only holding 11.5 volts or so....still started the bike fine, but it usually holds 13 or a smidge under 13volts.  So I replaced the battery and it holds 13 again.  I have  anew alternator ready to go in, but the old one is still putting out at or near 14Volts.  I guess amps is another story and I dont have an ammeter, but this volt meter seems to be serving well so far
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #33 on: June 28, 2010, 03:35:32 AM »
Hey KW, 7.5 years from my stock battery. Never been on a tender, never taken indoors,(Florida)
  I was impressed too. I was lucky, gave it up in the garage cooldude
Cliff
Manchester, NH
« Reply #34 on: June 28, 2010, 04:15:07 AM »
Black Dog
   +1  cooldude
VRCC # 29680
« Reply #35 on: June 28, 2010, 08:55:13 AM »
I think the voltmeter is very adequate. Don't see where an ammeter would do you any better.
Tailgate Tommy
Fort Collins, Colorado
« Reply #36 on: June 28, 2010, 05:12:00 PM »
6 years on the original battery in my '03 (bought the bike new in '04). I do use a battery tender.
vmb
Mississippi
« Reply #37 on: June 28, 2010, 05:50:52 PM »
Speaking of sulfation, what effect, if any, does draining a battery have on its ability to be recharged?
Mr. Nuts
Bitterroot Valley Montana
« Reply #38 on: June 28, 2010, 07:19:29 PM »
Free shipping, and a $59.95 Valkyire battery from:
http://www.tristatebattery.com/product_info.php?products_id=732
It is a motocross brand manufactured by Yuasa they say. Looks just like my oem. Got it fast.
Had a harley guy brag about paying $148 for his battery while my wife and I were on a ride last weekend. I asked "why so much?" He said "they put it through grueling tests in a paint shaker for days on end and it didn't loose its charge". I looked kind puzzled and said "I guess that WOULD be an important test on a Harley battery.." and started up the Valk. Made my getaway before my wife broke out laughing. I was feeling kind that day and resisted a strong urge to show him the nickle trick.
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
