November 21, 2025, 10:20:34 PM *
Author Topic: Going to the darkside-what do I need??  (Read 1710 times)
ohshooter
« on: September 24, 2010, 05:53:02 AM »
I just got a General Altimax tire and I know there are things I need to do while I have the back end open.
Check/replace brake pads, check shaft splines, what seals will I need?, anything else? I want to make sure I have everything when I start.
Gryphon
Resistance is futile; if less than 1 ohm.
Fulton, MO
« Reply #1 on: September 24, 2010, 06:33:20 AM »
You should probably consider doing the "nut cage mod" while you are there for the added clearance.  Other than that, it shouldn't be any different than the usual 10K service: i.e. lube the splines, check/replace the O-Rings (remember there are 3 of them), check the splines on the drive shaft, etc.
You've just gone to a different tire.  Ride carefully for the first few hundred miles until you've gotten used to the differences and worn off the "slick" of a new tire.
Have fun.
2qmedic
Simply Awesome!!!
« Reply #2 on: September 24, 2010, 09:21:46 AM »
As I found out when my Valk and I went to the darkside.
Patience with dialing in the psi,
Patience with braking in the tire,
Patience in giving your self time before you say "this ain't for me".
It took me about 1200 miles and then it seemed to "settle in" per say
(or was it me that finally got settled in?)
38 psi works for me
Hope this helps cooldude
Dave Weaver
Seymour, IN
« Reply #3 on: September 24, 2010, 05:44:57 PM »
These are all handy to have "just in case".  Thrust washer, rear wheel bearings, new metal 90 degree valve stem, o-ring set, rear wheel dampers, dust seal.
Do unto others as you would have them do unto you.
N8171S
Marlboro, Mass
« Reply #4 on: September 24, 2010, 06:20:27 PM »
Definatly change out the stock valve stem.  The originals are junk and even unsafe when they get a few years on them.
Bob E.
Canonsburg, PA
« Reply #5 on: September 25, 2010, 05:57:33 AM »
Take a look at the inside of your swingarm driveshaft tube where it will be closest to the tire.  Mine had a raised seam in the corner brace of the swingarm that caused a rub.  But I was able to knock it down with a hammer and all was good.
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #6 on: September 27, 2010, 02:12:39 PM »
No one mentioned it, but you need one of these, too...I just ordered mine yesterday.
Now, if I can just find my tire! Still having difficulties.
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
